addFeature to Feature Server using python
4176
06-22-2015 01:45 AM
ElliottCarson
I'm trying to add a feature to a Feature Server using python without any success.
When running the script I get the following error HTTPError: HTTP Error 401: Unauthorized.
The service only requires windows authentication of a user logged into the network, the service does not require a username or password.
How can this be achieved in Python?
My code so far is:
add = [{ "geometry" : {"x" : 20.8,"y" : -115.5},"attributes" : {"COMMENTS" : "Test"}}]
service_url = r"http://<servername>/ags/rest/services/test/testlyr/FeatureServer/"
params = urllib.urlencode({'f': 'json', 'features': add})
req = urllib2.Request("{0}/addFeatures/?".format(service_url, params))
response = urllib2.urlopen(req)
jsonResult = json.load(response)
print jsonResult
Regards,
Elliott
ElliottCarson
I manage to get the following to work with a username an password.
If someone knows how to get the current users credentials and pass that instead it would be most helpful.
import urllib, urllib2
from ntlm import HTTPNtlmAuthHandler
user = 'DOMAIN\user'
password = "password"
url = "http://<server>/arcgis/rest/services/Test/FeatureServer/0/addFeatures"
updateAttr = [{ "geometry" : {"x" : XXX,"y" : XXX},"attributes" : {"COMMENTS" : "WORK"}}]
params = urllib.urlencode({'f': 'json', 'features': updateAttr})
passman = urllib2.HTTPPasswordMgrWithDefaultRealm()
passman.add_password(None, url, user, password)
# create the NTLM authentication handler
auth_NTLM = HTTPNtlmAuthHandler.HTTPNtlmAuthHandler(passman)
# create and install the opener
opener = urllib2.build_opener(auth_NTLM)
urllib2.install_opener(opener)
url1 = urllib2.Request(updateBaseURL,params)
# retrieve the result
response = urllib2.urlopen(url1)
print(response.read())
