How to replace a "Picture_Element" in multiple Mxd's?
3549
5
06-22-2015 04:07 PM
G__EricCastillo_Morales
HI, I am trying to loop this script in 35 mxd's, in different folders, but I don't know how. Can someone help me?
Eric
import arcpy
mxd = arcpy.mapping.MapDocument(r"D:\Test\D1.mxd")
locfinal = arcpy.mapping.ListLayoutElements(mxd,"PICTURE_ELEMENT","Localización2")
for object in locfinal:
    object.sourceImage = r"D:\Test\Picture\test_picture.jpg"
    object.name = "loc mun estatal"
    object.elementHeight = 9.4827
    object.elementWidth = 11.99
    object.elementPositionX = 77.0
    object.elementPositionY = 94.0
mxd.saveACopy(r"D:\Test\D1copy.mxd")
XanderBakker
Esri Esteemed Contributor
Oops... I forgot to call the function that changes the picture element and saves a copy (see line 17)... Did a small test and it seems to work. Please note that there is no error checking what so ever in the code.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import arcpy
import os
def main():
    # path to folder where all mxd files reside
    path = r"D:\Test"
    # recursive loop through folder and sub folders
    for root, dirs, files in os.walk(path):
        for filename in files:
            if filename.endswith('.mxd'):
                # use only mxd files
                mxd_in = os.path.join(root, filename)
                print"Processing: {0}".format(mxd_in)
                updateLayout(mxd_in)
def updateLayout(mxd_in):
    path, name_ext = os.path.split(mxd_in)
    name, ext = os.path.splitext(name_ext)
    mxd_out = os.path.join(path, "{0}Copy.{1}".format(name, ext))
    mxd = arcpy.mapping.MapDocument(mxd_in)
    mxd.saveACopy(mxd_out)
    del mxd
if __name__ == '__main__':
    main()
XanderBakker
You could probably use the os.walk to loop through the mxd's like shown in the code below.
Please note that the code has not been tested and is based on a number of assumptions.
Change your path to the mxd's on line 8. The code will loop through that folder and all sub folders and process all mxd's it will find.
import arcpy
import os
def main():
    path = r"C:\Forum"
    del mxd
    main()
hi, I change the path, but nothing happen
... # -*- coding: utf-8 -*-
... import arcpy
... import os
... def main():
...     # path to folder where all mxd files reside
...     path = r"D:\Test"
...     # recursive loop through folder and sub folders
...     for root, dirs, files in os.walk(path):
...         for filename in files:
...             if filename.endswith('.mxd'):
...                 # use only mxd files
...                 mxd_in = os.path.join(root, filename)
... def updateLayout(mxd_in):
...     path, name_ext = os.path.split(mxd_in)
...     name, ext = os.path.splitext(name_ext)
...     mxd_out = os.path.join(path, "{0}Copy.{1}".format(name, ext))
...     mxd = arcpy.mapping.MapDocument(mxd_in)
...     locfinal = arcpy.mapping.ListLayoutElements(mxd,"PICTURE_ELEMENT","Localización2")
...     for object in locfinal:
...         object.sourceImage = r"D:\Test\Picture\test_picture.jpg"
...         object.name = "loc mun estatal"
...         object.elementHeight = 9.4827
...         object.elementWidth = 11.99
...         object.elementPositionX = 77.0
...         object.elementPositionY = 94.0
...     mxd.saveACopy(mxd_out)
...     del mxd
... if __name__ == '__main__':
...     main()
XanderBakker
import arcpy
import os
def main():
    path = r"D:\Test"
    del mxd
    main()
The script work !
thanks for your help.
I notice that the script run fine in python window, however when I run it in pyscripter don´t work, I mean when I check the copy  (D1Copy..mxd) the old picture remains.
Any way thanks.
Eric
XanderBakker
Interesting..., I could probably change the code a bit to run within ArcMap (because I assume this must be possible), but if you have no problem running it as standalone code. then let's leave it as it is.
