Showing Images On Map
4093
7
06-22-2015 07:56 AM
CeyhunYilmaz
Hi ,
I have an wms server and i want to use this service's GetMap function via url get query. I done it and i get an picture/image result which png/geotiff/kml etc. type. But there is a problem with show this image on the map. Image has an its extend scale like in the attachment.
Query url like below :
http://giswebservices.massgis.state.ma.us/geoserver/wms
Is there any way show image with/without coordinates on the map ?
Thanks.
ThomasDunn
Yes. Here is a C++ sample demonstrating what you can do with WMS with the C++ API.
https://developers.arcgis.com/qt/cpp/sample-code/wms_layer_sample.htm
You can download the sample from https://developers.arcgis.com/qt/cpp/sample-code/
I hope this helps.
ThomasDunn
Hello. I would like to understand this issue better, so here are some questions. Some answers may seem obvious, but I want to understand clearly.
- Is the attached PNG file the actual file that was returned from the WMS service?
- If so, was this image returned from the service whose URL begins with cbsservis.tkgm.gov.tr/tkgm.ows/wms?
- Should the image only contain the Antalya province?
- Are you using the Runtime SDK for Qt C++ (Qt Widgets) API or the QML (Qt Quick) API?
- Can you share the part of the code that displays the image on the map?
Thank you.
CeyhunYilmaz
Url which start with geonet is extra . There is   misspelling.
1. Yes Png file type. But service support many image type like  jpeg,tiff,geotiff. Also there are atom,kml etc
2.Yes
3.Yes
4. Mostly Qml. Actually we have developed with qml because of JS support and easy to use.
5.
    Envelope  {
        xMin: 25.382409179687
        yMin: 35.74005859375
        xMax: 44.144582031249
        yMax: 41.913056640624
        spatialReference.wkid: 4326
    Rectangle {
        width: 1003
        height: 400
        Map {
            transformOrigin: Item.Right
            anchors.fill: parent
            rotationByPinchingEnabled: true
            magnifierOnPressAndHoldEnabled: true
            mapPanningByMagnifierEnabled: true
            focus:true
            ArcGISDynamicMapServiceLayer{
                url: "http://server.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer"
            extent:sfExtent
        // Create a flickable to view a large image.
        Flickable {
            anchors.fill:parent
            contentWidth: picture.width
            contentHeight: picture.height
            Image {
                source:"";
                asynchronous: true
                opacity: 0.8
            states: State {
                when: view.movingVertically || view.movingHorizontally
                PropertyChanges { target: verticalScrollBar; opacity: 0.1 }
                PropertyChanges { target: horizontalScrollBar; opacity: 0.1 }
            transitions: Transition {
                NumberAnimation { properties: "opacity"; duration: 400 }
        ScrollBar {
            width: 12; height: view.height-12
            anchors.right: view.right
            opacity: 0
            orientation: Qt.Vertical
            position: view.visibleArea.yPosition
            pageSize: view.visibleArea.heightRatio
        ScrollBar {
            width: view.width-12; height: 12
            anchors.bottom: view.bottom
            opacity: 0
            orientation: Qt.Horizontal
            position: view.visibleArea.xPosition
            pageSize: view.visibleArea.widthRatio
And Final thank you
ThomasDunn
The source for the Image component gets a map as a PNG from the service. This is a raster image file. You can display it as an Image but you cannot add it as a Layer in the Map.
CeyhunYilmaz
Hi Thomas,
thanks for reply
Is there any way show this image on the map with right place (with spatial reference)? I ask it to you because  we develop an project with this services and other wfs services (for table queries) and showing this image or wms layer last part. I will be very plesant if i can do that with your help.
Regards.
ThomasDunn
Hello, Ceyhun,
I wish I could offer you something, but there is nothing in the QML API in 10.2.6 to support adding the raster to a layer in the map.
-- Thomas
CeyhunYilmaz
Hi Thomas,
is there in qt c++ api ?
ThomasDunn
I hope this helps.
