I have installed both web adapter and Arcgis server on same machine and configures security as HTTP and HTTPS . However when I tries to start Publishing services the dialog comes and doesn't finish at all. Please note I have changed only HTTP and HTTPS settings.
Hi Shafi,
Try publishing a small dataset. Does the publishing dialog still hang?
Few questions:
What is the server URL that you have used to connect to ArcGIS Server from ArcCatalog?
What capabilities are you providing to the services?
What Database are you using?
Hi Shafi,
Are you able to stop/start any of the other services? Try to do this from the server manager endpoint rather than from ArcMap/ArcCatalog
If not I recommend running the 'Configure ArcGIS Server Account' program that comes with ArcGIS Server (It can be found from the start menu > All programs > ArcGIS > ArcGIS for Server).
