Query Data from Related Tables
6767
11
06-19-2015 04:16 AM
IonutAlixandroae4
Hi colleagues,
I have a question regarding using Query Widget from WAB to query data both from the feature layer`s attribute table and from the tables related to the feature layer by a simple, 1-M relationship class.
In the update from February 2015 appeared that there is support for related records in pop-up, attribute table and query results.
Do you guys have any ideas?
Thanks!
Ionut
Tags (1)
RobertScheitlin__GISP
Ionut,
    That is correct the Popups, Attribute Table, and Query Results all now show related records for the selected feature. Are you not seeing this?
IonutAlixandroae4
Hi Robert,
I thought it will be possible to create filters/queries on related data. (Similar to "Select by attributes" but only on related data...)
Ionut,
   No querying related data is not currently supported. You can display related data for a feature that is queried, clicked/selected.
IonutAlixandroae4
OK, I understand.
Thanks!
JenniferFrazer
I have the same type of problem, however I have set-up a query off the parent table (not the connective tables) and my Query is not working.
When I use it, is gives me that the record is found, but it does not let the results appear in the results list (all I am trying to show in the results output is parent table data as well).
The goal is to allow users to query for a well# and quickly zoom to it.
This is a well dataset with 65,300 pts.
Other queries in my app is working (T&R, leases, etc), just the one well dataset with the connective table is giving me problems.
IonutAlixandroae4
Hi Jennifer,
So you query the data from the parent table and you can run a query but can not see the results?
Well, for what I understood, have you setup the results in the filter configuration in WAB? Like checking the field/data you want to appear?
Ionut
JenniferFrazer
Yes I have the returning results as just the API # from the parent table.  When I run the query is just states the # of records found, with no results.
Jianxia
Jennifer,
Is the parent table a Feature layer? or stand alone table? If it is a feature layer, you should be able to query and return results. Could you give the same service a try in map viewer with Filter?
JenniferFrazer
It is a feature layer. Tried it in map viewer and the filter does work when I query one well number out. The info for that one well does appear in the table (when I bring the table up).
