Python get two values in a Search Cursor than go to next line
6013
12
06-18-2015 07:22 AM
deleted-user-MS0lE1F_0-sy
I am trying to write my getValues to a text element loop, but I want there to be two results per line before going to the new line.  I am having trouble figuring it out? I think I might new a while loop perhaps instead of a for loop, and probably need to use next() somewhere?  But that seems to just loop through each name and put one result instead of all four.
I don't want this:   Anna                              I want this:   Anna  Ben
                             Ben                                                    Charlie Dora
                             Charlie
                             Dora
I don't know what to use in here to achive this.
rows = arcpy.SearchCursor(Layer)
        textValue = ""
        for row in rows:
            textValue += row.getValue(Value1) + '\r\n'
        ParcelText2.text = textValue
        del rows
TomSellsted
Matthew,
Just a bit of a logic error.  This should work:
textValue = ""
count = 1
for row in rows:
    if (count%2):
        textValue += row.getValue(Value1) + '  '
    else:
        textValue += row.getValue(Value) + '\r\n'
    count +=  1
Regards,
Tom
IanMurray
Honored Contributor
should be fairly easy to use a counter or something similar to check.
textValue = ""
for row in rows:
    count = 1
    if count/2.0.is_integer() == False:
         count += 1
    else:
         count += 1
del rows
TomSellsted
Matthew,
Some logic like Ian describes will work.  You can use the modulo operator to accomplish this too.
if (count%2) == 0:
Regards,
Tom
IanMurray
Honored Contributor
That was probably the better one to use, my general python gets rustier and rustier I feel like since I am only use python within the arcpy module these days(and with a limited usage at that!).
TomSellsted
There are always lots of different ways to solve problems!
DanPatterson_Retired
in fact you don't even need the equality test since it will either be 1 or 0
which equates to a Boolean without the danger of comparing to a number
>>> a = [ not(i%2) for i in range(11)]
>>> b = [ (i%2)== 0 for i in range(11)]
>>> a
[True, False, True, False, True, False, True, False, True, False, True]
>>> b
>>> a == b
True
TomSellsted
You are correct sir!
Ian/Tom,
I have tried the different versions and it still gets written like this:  Anna        &        I want this:  Anna  Ben
        Ben                                        Charlie Dora
        Charlie
        Dora
textValue = ""
for row in rows:
     count = 1
     if (count%2) == 0:
          count += 1
      else:
          count +=  1
TomSellsted
Matthew,
textValue = ""
count = 1
for row in rows:
    if (count%2):
    else:
    count +=  1
Regards,
Tom
Perfect! Thank you all, I love this community, I have learned a lot here.
