How to track cache status in ArcGIS Server 10.0
2997
06-16-2015 06:03 AM
EugeniuCepoi1
Hi everyone...
I would ask for help on the next issue: I try to cache a service (in ArcGIS Server 10.0) and I would like to view the status of caching. Can someone tell how is it possible?
Thanks!
JayantaPoddar
MVP Esteemed Contributor
Hi Eugeniu,
I currently don't have the 10.0 setup. Have you tried this:  Viewing Cache completion status
Think Location
EugeniuCepoi1
Hi Jayanta,
Unfortunately " Viewing Cache" appeared in ArcGIS 10.1. In ArcGIS 10.0 there is no such function.
Thanks for reply.
JenniferMcCall4
To get a visual representation on the cache status, you can copy the Status.gdb to your desktop (or a location not in the arcgisserver folder.  Once it's copied to a new location, you can add the feature classes within it to ArcMap.  I believe you want the TaskStatus feature class.  There is a lot of information in the attribute table that you can filter on.  You can see the bundles that have been completed or had errors, see the time of completion for that bundle, and the scale.  If you sort on time, you can see which bundles were created last and determine an approximate status.
