Portable version of ArcGIS Runtime SDK for .NET?
4733
7
06-14-2015 11:27 AM
marceloctorres
There is  or there will be a Portable versión of the ArcGIS Runtime SDK for .NET or for a part of it?
Marcelo César Torres
dotMorten_esri
Esri Notable Contributor
...See the first 3 projects in this demo repo which uses shared projects for sharing business logic for all the target platforms: Esri/arcgis-runtime-demos-dotnet · GitHub
AnttiKajanus1
We don't have PCL version of the API due technology limitations in PCL.
marceloctorres
But is very usefull when one have to make versions for many platforms: using Universal Apps paradigma answer the problem for Windows Store 8.1 / Windows Phone 8.1, but when the scope must be more wide?. PCL don't resolve all issues and have to rewritte a lot of code of the presentation layer, but bussiness and data layer of the App can be shared using PCL.
dotMorten_esri
My suggestion is to use "shared projects" instead for sharing your source code among multiple platforms. It's like having a PCL project, except you don't compile a PCL binary, but just compile the source straight into the app.
marceloctorres
"Shared Projects" work for Universal Apps only...(Windows Phone 8.1, Window 8.1)....
dotMorten_esri
That's not correct. You can use shared projects for ANY project type (WPF, Universal, Console, Silverlight etc), and both VB, C# and C++. In fact almost all the code in the .NET SDK are in shared projects, and then compiled for each platform, with only a little bit of platform specific code here and there.
Also this extension might be helpful for you if you're using VS2013 (2015 has this built in):
Shared Project Reference Manager extension
Before this extension existed, you had to do it manually, which I blogged about here: SharpGIS | Behind the scenes of “Universal Apps”  That should give you a little more understanding of how shared projects really work.
dotMorten_esri
marceloctorres
Thanks, in fact, I am developing a cross-platform app with Xamarin.Forms (iOS, Android, UWP) and ArcGIS Runtime SDK for .NET using "shared projects".
