Cannot display selection set
2898
06-15-2015 10:57 PM
ModyBuchbinder
We have a strange problem with display selection set in ArcMap.
On some machines with some layers when the selection set have more features it is not displayed.
For example we have a polygon layer with 2000 features in ArcSDE.
When we select less than 150 it works. When it is more features it is not displayed.
The status line at the bottom say 200 feature selected.
When open the attribute table it say 200 features selected and show them highlighted in the table.
Zoom to select works.
If you do identify box on these 200 features and move them to select – it works!!
The same problem exists with select by attribute and selection above 150 features is not displayed.
The same layer in FGDB works fine.
On some other machines the same layer works.
On the same machine some other layers works or the number of features you can select
is different then 150.
It looks like drawing the selected is the only problem all other functionality on the selected works.
Any ideas?
Mody
jorisfrenkel
Just seeing this item now. Would this have anything to do with the issue described in the following KB article?
37841 - Slow performance making large selections from SDO_Geometry feature classes in ArcMap
