Error when using iteration in Zonal table as Statistics
4636
6
06-14-2015 08:21 PM
bilalcelik1
I am pretty new in ArcGIS, however I was able to create my script accept the last step.
I am using night lights to get my data. I light data for several years, i want to get my data for each year. I was able to generate iterations and it is working accept last step.
Here is my code:
# Import arcpy module
import arcpy
from arcpy import env
from arcpy.sa import *
arcpy.env.workspace = r"D:\Research-NightLights\yeni"
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Local variables:
Tur_pro_09 = "D:\\Turkey09\\admin\\Turpro09.shp"
Tur_lyr = "D:\\Turkey09\\admin\\Turkey"
Tur_dist_09 = "D:\\Turkey2009\\admin\\Turdist09.shp"
arcpy.MakeFeatureLayer_management(Tur_pro_09, Turkey_lyr)
print "makefeature"
# Process: Select Layer By Attribute
arcpy.SelectLayerByAttribute_management(Tur_lyr, "NEW_SELECTION", "\"ID\" = '01'")
print "attribute"
rasterList = arcpy.ListRasters("f*")
for raster in rasterList:
    print "list"
# Process: Clip (1)
    arcpy.Clip_management(raster, "25.665181 35.812875 44.826408 42.104629", "y1"+str(raster[1:]), Tur_lyr, "255", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
print "clip1"
rasterList1 = arcpy.ListRasters("y1*")
for raster in rasterList1:
    print "list (2)"
# Process: Raster to Polygon
    arcpy.RasterToPolygon_conversion(raster,"y2"+str(raster[1:]), "NO_SIMPLIFY", "Value")
print "polygon"
fcs = arcpy.ListFeatureClasses("y2*", "polygon")
for raster in fcs:
    print "poly_clip"
# Process: Clip (2)
arcpy.Clip_analysis(Tur_dist_09, raster, "y3"+str(raster[1:]), "")
print "clip2"
rasterList3 = arcpy.ListRasters("y1*")
for raster in rasterList3:
    print "list (3)"
# Process: Zonal Statistics as Table
    arcpy.gp.ZonalStatisticsAsTable_sa(Turdist_09, "Name", raster,"j"+str(raster[5:])+".dbf", "DATA", "MEAN")
    arcpy.Delete_management(raster)
    print "Got zonal stats for "
Here is the Error I get: (it works perfect until Zonal Statistics as Table step)
  File "C:/Users/Bilalce/Desktop/fully working12.py", line 64, in <module>
    arcpy.gp.ZonalStatisticsAsTable_sa(Turkey_districts_2009, "Name", raster,"j"+str(raster[5:])+".dbf", "DATA", "MEAN")
  File "C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
ExecuteError: ERROR 999999: Error executing function.
Create output table failed
Failed to execute (ZonalStatisticsAsTable).
(Curtis Price added formatting)
curtvprice
Looks to me like the expression:
may be creating an invalid pathname (a common cause of 999999 errors).
Also, why aren't you simply using this syntax?
arcpy.sa.ZonalStatisticsAsTable(args)
curtvprice
bilalcelik1
I also think it is because of expression
Like I said I am pretty new. I created my script using model builder. model builder is using
arcpy.gp.ZonalStatisticsAsTable_sa() syntax
I also used help from the script in http://economics.mit.edu/files/8955
He is also using  arcpy.gp.ZonalStatisticsAsTable_sa() syntax.
and I got expression of "j"+str(raster[5:])+".dbf" from this the webpage above.
I don't know how to correct the output expression so I can get output for each year.
Any help is appreciated.
Thanks in advance.
XanderBakker
Esri Esteemed Contributor
Moved the thread to the Python space...
NeilAyres
So, what does the value of your variable "raster" look like in each of the loops.
Perhaps examine this more carefully.
bilalcelik1
Thank you so much for your requests. I don't think there are any problem value of the raster in each loop. Here if I don't make any loop in the last step, script works perfectly. Here is the changes that I made to get rid off loop in the last step.
I added two local variable:
y1121998="D:\\Research-NightLights\\yeni\\y1121998.tif"
zonalst_shp23="C:\\Users\\Bilalce\\Documents\\ArcGIS\\Default.gdb\\ZonalSt_shp23"
Then changed last Zonal Statistics as table step as:
# Process: Zonal Statistics as Table, and got rid of the loop before zonal statistics as table step.
arcpy.gp.ZonalStatisticsAsTable_sa(Turkey_districts_2009, "Name", y1121998,zonalst_shp23, "DATA", "ALL")
It works perfectly. Thus i am thinking, problem is related to expression of "j"+str(raster[5:])+".dbf".
But I don't know how to change this expression so I can get output for every year.
bilalcelik1
Okay, I solved problem. I changed the code in last part as Curtis advice. I used
arcpy.sa.ZonalStatisticsAsTable(Tur_dist_09, "Name", raster,
                                  "j"+str(raster[5:]), "DATA", "ALL")
Now it is all good.
Thank you so much
