QT ArcGIS SDK, QML and C++ objects interoperability.
4290
06-12-2015 12:15 AM
AlexMerkulov
Hello anybody,
I'm implementing mobile viewer for our Geographic Information System (GIM gim.tahal-gal.com/gim2xu/). Some things I thought to move to C++ level, but I met the fact that I can't use in C++ code objects created in QML. Why? Why natural interoperability of QT QML is broken in QT SDK?
I spend few days to understand the problem when I found this this thing in SDK release note:
"Interoperability between identical object instances from both the C++ and QML APIs is not supported. For example, passing a Point geometry object from QML to C++ and performing geometry operations on that Point in C++ is not supported."
Why I can't cast QML Layer to C++ Layer? It is the same objects!!!!
Is this commercial or technical issue?
Regards.
Alex Merkulov
Tags (1)
LucasDanzinger
Esri Frequent Contributor
Hey Alex-
The QML API wasn't originally architected in a way to let you do this, so it is a technical limitation as of now. The C++ objects and QML objects are in fact not actually the same objects under the hood. We are looking at supporting this in the future, but for now, you will need to use the Runtime API in either C++ or QML.
Luke
AlexMerkulov
Thanks Luke, I got it
