Change default size of widget
4652
06-11-2015 04:23 PM
ChadTinsley
How do I change the default size of a widget? I have a query widget that I would like to have default to a larger size to show more of the content. I already changed the main config to have the widget "openAtStart".
-Chad
RobertScheitlin__GISP
Chad,
   In the main config you can also set the height and width of the widget as well.
Chad,
ChadTinsley
Ahhh, so easy. Thank you kindly, Robert!
StanMcShinsky
Chad,
Also depending on what you are looking for you may find this thread helpful as well.
Widget in Panel Height
-Stan
