Assign coded value domains to mosaic dataset fields - possible??
3335
06-11-2015 07:33 AM
PeterLen
We are using ArcGIS 10.2 with Python 2.7.  I am trying to add a coded value domain to a field in my mosaic dataset.  I used arcpy to create the domain in my file GDB and then to add the values to that domain.  I then tried to use the AssignDomainToField_management tool to add the domain to a field in my mosaic dataset but it failed.  As I looked closer at the help, the input must either be a table or feature class.  I know that mosaic datasets use coded value domains because there is a Category field that was created in my mosaic dataset which points to a domain located in the file GDB.
Does anyone know what I need to do to assign an existing domain to a field in a mosaic dataset?
Thanks for any thoughts - Peter
