Parking lot and private street
6263
06-05-2015 01:23 PM
BrianLomas
I new to city engine so I apologize if this is an "easy question". I what to create a complex parking area that has private streets running throughout. Are there any rules that can acomplish this? Any help would be greatly appreciated, thanks.
Tags (1)
BlakeHarcourt
It's going to a bit tricky but here is what i did quickly:
1. Create a road network and turn off block generation. Apply your road rule.
2. Create/import polygons for the car parks. Apply a rule to texture them.
3. Then create/import polygons for the dividers and areas between the car parks and the road.Then apply a rule to them to extrude them and texture them.
BlakeHarcourt
BenLeslie1
I reckon you should be using the Sidewalk geometry as the parking spots.  Here's something very simple I knocked up in 2 mins - loads of potential to improve it....
attr valency = 3
attr type = "unknown"
attr spotWidth = 3
Sidewalk-->split(x){spotWidth:SplitGeom}*
SplitGeom-->
case valency < 3 || type == "unknown": NIL
else: ParkingSpot
Make sure you change valency and type to object defined attributes - have a look at these attributes in the objects hopefully you'll see what I'm getting at (I'm trying to exclude the bits of geometry that are too small/ too curved to be a parking spot) and be able to make improvements.  Also have a look as the 'Repeat Split' section in the help guide - you'll be able to make other improvements with that info.
