Random FileGPSLayer error
4191
5
06-04-2015 11:22 PM
PremRadhakrishnan
I am getting this error whenever I load a FeatureLayer using a GeodatabaseFeatureServiceTable . There is one exception per feature in the FeatureLayer and it only happens once per load . So I have 77 features in the featureservice I am loading the following exception happens 77 times when the application first loads. It does not happen again.
Exception at 0x7ff810fe8b9c, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in EsriRuntimeQtd!EsriRuntimeQt::FileGPSLayer::qt_static_metacall
Is this something I should be concerned about ?
Cheers
Prem
PremRadhakrishnan
After upgrading to 10.2.6 this has changed to and now it happens not just the first time but every time the map changes and I do not see a correlation of the number of errors and number of features
D3D11 ERROR: ID3D11DeviceContext::RSSetScissorRects: ScissorRect at slot 0 is invalid. Valid Rects have left (value = 0) <= right (value = -4) and top (value = 446) <= bottom (value = 527). [ STATE_SETTING ERROR #260: DEVICE_RSSETSCISSORRECTS_INVALIDSCISSOR]
This is not affecting anything that I am doing yet, but I am not sure if that will remain true as I add more functionality to the application. As you can see the layer is pretty simple its a point layer with a unique value renderer . If I turn the layer off then the errors stop so I am sure that it is related to this particular layer which is loaded from a secure Feature Service.
LucasDanzinger
Esri Frequent Contributor
Prem-
Can you please send some code + the service you are using to reproduce? We have not seen this error before.
Luke
PremRadhakrishnan
Lucas,
All I am doing it generating a geodatabase from a feature service and then displaying those local features. Since its secure I emailed you the creds of the feature service.
It happens both when I am displaying the feature service live and when I am displaying it from the generated geodatbase. The error is displayed in the Application/Output Panel.
Regards,
Prem
AlexMerkulov
I have the same error in 10.2.5:
Exception at 0x7fefd84b3dd, code: 0xe06d7363: C++ exception, flags=0x1 (execution cannot be continued) (first chance) in EsriRuntimeQtd!EsriRuntimeQt::FileGPSLayer::qt_static_metacall
I have both GPS control and feature layer with GeodatabaseFeatureServiceTable on then map, looks like some misbehavior between them. This happens each time the requested feature comes from server.
Regards,
Alex
LucasDanzinger
Alex-
This sounds like it may be a bug. I suggest you contact Esri Support to have them investigate further and log a bug if appropriate.
Luke
