Oracle Database Connections Setup
3808
06-04-2015 03:46 AM
RusselQuan
I'm new to ArcGIS Server.
I have a ArcGIS Desktop map that I've connected to an Oracle database via Database Connections in the Catalog.  The data is contains my customers with Longitude and Latitude fields.  I want to publish that map to our internal ArcGIS Portal Dev and then Prod environment.  The database in the Dev environment is different than the Production environment.
1.  How do I set up database connections in the Server/Portal environment?
2. Can I parameterize the database connection so that the database connection does not have to be edited when publishing to each of the environments?
RQ
Tags (1)
George_Thompson
Esri Notable Contributor
Hi Russel,
You need to install the Oracle 64-bit client on the ArcGIS server machine. If you have more than 1 ArcGIS Server in a cluster, the client needs to be installed on each of the server machines.
Register an Oracle database with ArcGIS for Server:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Once the client is installed on the machine, be sure to restart the ArcGIS Server service. After the re-start you should be able to import the same connection file from the Desktop client and register your Oracle database.
Let me know if you have any issues.
-George
GeodatabaseManaging Data
--- George T.
RusselQuan
I'll follow this lead.  Thanks for the speedy response.
