OAuth2 authentication challenge
7999
7
06-03-2015 06:15 PM
ChristosStamatopoulos
Hi all,
I am attempting to switch my standard app licensing from Token to OAuth2.
Things is it is not challenging the user for credential and instead throws an Exception.
Esri.ArcGISRuntime.Http.ArcGISWebException: Error code '400' : 'Unable to generate token.'
'username' must be specified.
'password' must be specified.
I should say that It works fine with the token.
Here is what I do.
First set up our challenge handler
            // setup our sign challenge handler
            var signInChallengeHandler = new Esri.ArcGISRuntime.Toolkit.Security.SignInChallengeHandler()
                AllowSaveCredentials = true,
                CredentialSaveOption = Esri.ArcGISRuntime.Toolkit.Controls.CredentialSaveOption.Unselected
            Esri.ArcGISRuntime.Security.IdentityManager.Current.ChallengeHandler = signInChallengeHandler;
            Esri.ArcGISRuntime.Security.IdentityManager.Current.OAuthAuthorizeHandler =
                new Esri.ArcGISRuntime.Toolkit.Security.OAuthAuthorizeHandler();
          // code for basic license....
Second register the server
            var serverInfo = new ServerInfo()
                ServerUri = portalServerUrl,
                OAuthClientInfo = new OAuthClientInfo()
                    ClientId = "xxxxxx",
                    ClientSecret = "xxxxxxxxxx"
                TokenAuthenticationType = TokenAuthenticationType.OAuthAuthorizationCode
            Esri.ArcGISRuntime.Security.IdentityManager.Current.RegisterServer(serverInfo);
Finally request for the credentials
                var credRequest = new CredentialRequestInfo()
                    ServiceUri = portalServerUrl,
                var cred = await IdentityManager.Current.GetCredentialAsync(credRequest, true);
If instead I use
                  var cred = await IdentityManager.Current.GenerateCredentialAsync(portalServerUrl, "user", "pass");
I get Esri.ArcGISRuntime.Http.ArcGISWebException: Error code '400' : 'client_id not specified'
What am I missing here ?
DominiqueBroux
Esri Frequent Contributor
This should work. Does the OAuth authorization page show up?
AutorizationCode OAuth workflow doesn't support setting the user and password by the API. Password and access authorization must be explicitly validated by the user.
Though you can use GenerateCredentialAsync without specifying the user/password.
var cred = await IdentityManager.Current.GenerateCredentialAsync(portalServerUrl);
In this case, you should see the authorization page.
No that is the problem,
The OAuth authorization page does not show up at all and I just get the exception.
I get
DominiqueBroux
Actually it's likely because you didn't set the RedirectUri (sorry I should have noticed that earlier)
Try
                    RedirectUri = "urn:ietf:wg:oauth:2.0:oob"
Note: ClientSecret is optional
It is still not showing the authentication page. Same exception.
DominiqueBroux
Strange. The behavior is as if the server was not registered to use the OAuthAuthorizationCode workflow.
Could you post a simple repro case. I'll test my side.
Thanks.
Thank you,
Can I get an email address to sent you the repro case ?
DominiqueBroux
