map service not loading
4184
7
05-29-2015 09:25 AM
glennhazelton
Robert,
I have upgraded arcserver and portal to 10.3.1.
I was just attempting to add a new query and it seems the mapservices are not loading properly.
when I add the services the field do not populate in the box where I can select them.
there is also a red ! mark next to the rest url.
I have attached an image for you to see.
any ideas?
I have been having a variety of issue today.
for example I can only open the WAB-developer in IE (11), Chrome and FFox toss errors. maybe it is related.
I have attached that error as well
RobertScheitlin__GISP
Glenn,
    Is your server using ssl (https)? Those errors are indicating that the app is trying to use https.
glennhazelton
yes i am using https as that seems to be what portal requires for arcserver
Glenn,
   Can you bring up the rest service endpoint for your portal map services?
glennhazelton
yes i can add a service to the MAP tool in portal.
it seems very slow however
i attempted to do the query again a bit ago and it got the list of fields but i cant add an expression as the fields again don't show up.
maybe it is timing out or something.
ChrisSmith7
Honored Contributor
Are you sure the server isn't getting hammered or maybe needs a reboot? I hate to suggest that, but I have had oddities occur where this resolved the issue. Actually, while load testing ArcGIS, I had ArcSOC.exe processes spin-out of control (even after stopping the load test), pegging CPU, and had similar response issues.
glennhazelton
i will have it rebooted this evening
thanks for the idea.
ChrisSmith7
Honored Contributor
If it's just a specific service, maybe try and recycle it and see if that helps. I think out-of-the box it does this every 24 hours.
