Cannot read property 'ssl' of null on Launch
4930
05-28-2015 05:08 PM
AndrewTerwiel
I get this error in the console when I try to "Launch" my app. I found that an extra condition in the ConfigManager.js, where the error occurs, resolves this.
Line 472:
_processWebTier: function(appConfig){
    var def = new Deferred();
    var portalUrl = appConfig.portalUrl;
    if(appConfig.isWebTier){
        //Although it is recommended to enable ssl for IWA/PKI portal by Esri,
        //there is no force on the client. They still can use http for IWA/PKI.
        //It is not correnct to assume web-tier authorization only works with https.
        tokenUtils.isWebTierPortal(portalUrl).then(lang.hitch(this, function(isWebTier) {
            var credential = tokenUtils.getPortalCredential(portalUrl);
            if(credential){ // condition added by alterwiel
                if(credential.ssl){
                    //if credential.ssl, it means that the protal is allSSL enabled
                    if(window.location.protocol === 'http:' && !tokenUtils.isInConfigOrPreviewWindow()){
                        window.location.protocol = 'https:';
                        return;
            def.resolve(isWebTier);
        }), lang.hitch(this, function(err) {
            def.reject(err);
    }else{
        def.resolve(false);
    return def;
GrégoryFERELLOC
Same issue. same solution
Hope they will fix it in a new version (1.3? ).
AndrewTerwiel
In the meantime... another day, another bug to fix. That's what we're paid for.
