Kernel density of a set of points returns an empty raster
7989
5
05-28-2015 03:05 AM
IuliaKlimina1
Hello everyone
I'd like to calculate the Kernel density on a point shapefile. The shapefile is a result of a table with addresses that has been geocoded.
The Kernel Density tool is completed with a warning giving the following error:
000957 : Skipping feature(s) because of NULL or EMPTY geometry.
The resulting Kernel density is an empty raster.
I tried to resolve the error. I noticed that all records in the shapefile the field Shape* is completed as 'point' and no NULL values are to be found. I also tried to check the geometry (Data Management tools --> Features --> Check Geometry). This tool returned an empty table, meaning there were no issues found with the geometry.
Has anyone encountered this problem before? Any suggestions how to avoid it are welcome.
Thank you!
DanPatterson_Retired
doing it in the data frame isn't going to help...the data needs to be physically in a projected coordinate system, obtained by using the Project Tool in ArcToolbox, Data Management Tools, Projections and Transformations...Project
are you using projected data? What did you specify for the parameters in KernelDensity (in_features, population_field, {cell_size}, {search_radius}, {area_unit_scale_factor})
curtvprice
I agree with Dan that is probably best practice to project your points to match your raster (especially if you are having issues). Then try the default parameters and see if you get anywhere.
IuliaKlimina1
The population field is set to NONE, cell size, search radius and area unit are left default.
After I checked the transformations for the data frame, with the same settings the return raster is no longer empty, but a density raster as expected.
However, the error message still stands.
IuliaKlimina1
Dan, you are absolutely right!
I projected the data and the tool works perfectly now!
Thank you
