Create shortest path in a network
3258
05-27-2015 08:07 AM
MarlenaGötza
I created a geometric network from a line and a point feature class and used "Find Path" to trace the network. You can see the result in the screenshot.
Has anyone an idea how I can the remove the unneeded connections (framed in red) to ideally get the shortest path between all points?
Thanks for your help,
Marlena
KenBuja
MVP Esteemed Contributor
Please note that the GeoNet Help​ space is for the discussion of the workings of GeoNet, not about specific applications. This will be moved to the Network Analyst​ space, but move it to a more appropriate space if necessary.
