WebApp Builder Widgets Error
5018
05-23-2015 02:29 AM
ManeshSharma
HI all
How r u , Hope U r good.
Hey I need an help from you regarding the WebApp Builder Widgets Error : I have an federated Server. and Have Published the Data from the arcgis Desktop 10.3 to Portal for Arcgis 10.3. Firstly i was able to Pubilsh and Configure the Widgets From the Web App Builder .
Now a days I am facing the problem that when Ever i am trying to Load the Wdgets from the Widgets in web appbuilder when trying to make an web map Application and configuring the Widgets It is giving me the Error Load Widgets Resource Error : i have attached the Snap shot for the same.
to mention that all the Services in the Server are running and started.
Can you help me in the same.
Thanks a  lot
Tags (1)
RobertScheitlin__GISP
Manesh,
  It looks like you have a problem with your WAB paths in your setup. The error screenshot you provided indicated that all widget are unable to resolve their path to resources. A standard path should look like this: <install folder>\client\stemapp\widgets if you have any additional folders in this path you can have issues.
