ArcObjects 10.2 Error Under Debug Mode of Visual Studio 2010
5690
05-12-2015 02:02 PM
JW1
I get stuck with this ArcObjects 10.2.2 debug problem.
My environment
    • Win7 64 bit
    • ArcGIS Desktop (ArcInfo) 10.2.2.3553
    • Visual Studio 2010 Pro
Problem
My application use IMapDocument interface of ESRI.ArcGIS.Carto to open MXD document. If the document has a raster Map Service layer(Map Service Type: Cached;File Format:PNG32), I will get errors under debug mode of Visual Studio when the application try to open it.
The exception message - "Access Denied. (Exception from HRESULT: 0x80030005 (STG_E_ACCESSDENIED))"
And the windows event viewer does come with an error about ESRI’s RasterDB.dll
See screenshot
    • I tried on other virtual machine, same problem.
    • I tried to add the raster layer from other Map Server, same problem.
    • I also tried to add other raster layer (open street base map), same problem.
However,
  • this document can be opened properly with ArcMap 10.0, 10.2 and 10.2.2.
  • If I remove the raster layer from the MXD document, no problem in debug mode.
  • or if I just run the compiled exe file directly, everything is fine.
  • If I change the raster layer into other type of Map Service layer (Map Service Type: Not Cached), no problem.
see screenshot​
JW1
Problem solved.
This error should be related to a module (CSM.dll) conflict between ESRI's raster library and Microsoft's remote debugging library (VS7 Causality Stack Manager).
thanks John Simonitch​ for a similar post
ArcEngine .Net 10.1 sp1 Entry Point Not Found ?Base64Decode Error...
