Appending Data periodically to a SDE Feature Class
4468
05-10-2015 06:45 PM
timdunlevie
Hi all,
I'm pretty new to this but we have a ArcGIS database with many Feature Classes.
I have one Feature Class with around 65,000 objects which I want to update on a monthly basis.
I need to be able to compare records from one month to the other.
What is the best practise to do this?
I was thinking of utilising a date-loaded field so that I can compare the months?
Or should I be using versioning?
The Feature Class will eventually have > 1,000,000 records if I keep appending new monthly data to this feature class each month.
I am hoping to compare changes in objects across many months.
Any advice would be appreciated.
NeilAyres
Why don't you just enable editor tracking?
This provides created / edited dates and users automatically.
See here :
http://resources.arcgis.com/en/help/main/10.2/index.html#//00170000016p000000
timdunlevie
Good point…thanks.
I guess I’m worried that with months of updates (potentially years and appending lots of objects ~ 60K each time) might cause some speed issues to the Database down the track?
VinceAngelo
Esri Esteemed Contributor
Best practice is to only change the objects that really change.  I'd use a parallel table which is truncated with each new batch, then only add new records and update changed ones.  This will require a unique key which is not the rowid column (something in the data).  Archive History may also be of use.
- V
