Hi guys,
I'm new in creating add-ins and just trying to give it a shot. Currently the simple one I setup is not working for me. Basically the user enters an ID, then the button when clicked should change the definition query of a layer and the dataframe changes its extents to this lyr's extents. Just wanted to know where I went wrong. thanks,
import arcpy
import pythonaddins
class EnterQPIDNumberCBox(object):
"""Implementation for CreateQPIDMapExtent_addin.eqncombobox (ComboBox)"""
def __init__(self):
self.editable = True
self.enabled = True
self.dropdownWidth = 'WWWWWWWWWW'
self.width = 'WWWWWWWWWW'
def onSelChange(self, selection):
pass
def onEditChange(self, text):
global id_input
id_input = int(text)
def onFocus(self, focused):
pass
def onEnter(self):
self.items.append(id_input)
pass
def refresh(self):
pass
class QPIDToolsExt(object):
"""Implementation for CreateQPIDMapExtent_addin.qpextension (Extension)"""
def __init__(self):
# For performance considerations, please remove all unused methods in this class.
self.enabled = True
def activeViewChanged(self):
pass
def contentsChanged(self):
pass
class ZoomToPropertyButton(object):
"""Implementation for CreateQPIDMapExtent_addin.ztpbutton (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
mxd = arcpy.mapping.MapDocument('CURRENT')
df = arcpy.mapping.ListDataFrames(mxd)[0]
lyr = arcpy.mapping.ListLayers(mxd, '#', df)[0]
lyr.definitionQuery = "ID={0}".format(id_input)
ext = lyr.getExtension()
df.extent = ext
arcpy.RefreshActiveView()
