Set default value for a field in ArcMap using python
12782
18
05-06-2015 09:30 AM
StacyMcNeil
I have been trying to figure out how I can set a default value to a field in ArcMap.  I see there is a tool called Assign Default to field but that is applied to the entire dataset.  I would like the default to apply to the current ArcMap session only.  In the Create Features window you can right click a layer and set a default there to get the behavior I would like but am trying to accomplish this for multiple layers in the TOC using python.
This is what I have been trying, starting with one layer first, but get an error "The attribute 'defaultValue' is not supported on this instance of Field"  I can print the defaultValue however.
feature_class = "Roads"
fields = arcpy.ListFields(feature_class)
for field in fields:
     if field.name == "Project_Name":
          field.defaultValue = "Test_Project"
Forgive me if I am making an obvious mistake.  I am still a beginner.  Thanks for any help!
SepheFox
Hi Stacy, it looks like you're on the right track. Try using Assign Default Values, instead of field.defaultValue: Assign Default Values.
ChristianWells
Hi Stacy,
Try out the Assign Default To Field (Data Management) tool.
          arcpy.AssignDefaultToField_management(feature_class, "Project_Name", "Test_Project")
StacyMcNeil
Thanks Christian and Sephe.  I have tried th Assign Default to Field tool and the default value then gets applied to the entire feature class so anyone editing will have the same default value.  I need the default to change from map to map.  Any ideas on that?
BlakeTerhune
There's no easy, built-in way to do this. Have you considered using Subtypes? You can have different default field values based on whatever is chosen for the subtype.
curtvprice
You could package the mxd with a toolbox, with a model or script tool that runs that default value tool with a parameter for the value you set up or have them pick from a list. You can even a button on a toolbar in the mxd interface - and instruct the user to run it before editing.
Outside of that you would have to build an AddIn which may be more than you want to get into right now. That also would be a different learning curve on the user end (loading the addin, adding it to the interface) so I would prefer the first method anyway.
SepheFox
          mxd = arcpy.mapping.MapDocument("CURRENT")
          default = mxd.name()
          arcpy.AssignDefaultToField_management(feature_class, "Project_Name", default)
curtvprice
Here's a function implementation. BTW mxd does not a name property, just filePath.
import os
import arcpy
def AssignDefault(tbl, fld):
    try:
        fname = arcpy.ListFields(tbl, fld)[0].name
        default = os.path.splitext(arcpy.Describe(mxd.filePath).name)[0]
        arcpy.AssignDefaultToField_management(tbl, fname, default)
    except:
        print("Could not assign default")
StacyMcNeil
import os
import arcpy
tbl = "Roads"
fld = "Project_Name"
    try:
        print default
    except:
Thanks Curtis.  I will be creating a tool for the user to enter their Project Name but am keeping this simple for now since I don't even know what I am trying to do is possible.  I ran your code frmo ArcMap but nothing happened.  I added a print statement and that was not displayed either.  Any ideas?
DanPatterson_Retired
you never call the function ie
is needed as a line, and the function itself should be put at the top of your script after the import statements
