Issue with line containing NULL byte
13099
9
05-04-2015 03:31 PM
benberman
The script I currently have reads an existing csv and updates(writes to) the csv by refencing a feature class, its attribute fields, and associated domains from a GDB and then updates the domain values with the corresponding attribute field n
ames, in the spreadsheet(csv).
import arcpy,collections,re,csv
workspace= 'path to GDB'
file = 'path to csv'
input= 'path to feature class'
lstflds=arcpy.ListFields(input)
with open(file,"rb+") as f:
    reader=csv.reader(f)
    writer = csv.writer(f)
    mydict = collections.defaultdict(list)
    domains=arcpy.da.ListDomains(workspace)
    for domain in domains:
        if domain.type =='Text':
            coded_values=domain.codedValues
            for code,desc in coded_values.iteritems():
                mydict[domain.name].append(code)
    dict_dom={}
    for fld in lstflds:
        for dom,values in mydict.iteritems():
            if fld.domain==str(dom):
                dict_dom.update({fld.name:values})
    print dict_dom
    for row in reader:
        for key,val in dict_dom.items():
            if row[1]==key:
                char_removal = ["[","'","u"," ","]"]
                rx = '[' + re.escape(''.join(char_removal)) + ']'
                v=re.sub(rx,'', str(val))
                row[3]=v
                print row[3] # This lists the domain codes just fine as they would be written to the spreadsheet
                writer.writerow(row) # This is where the script returns the NULL error
As the last 2 commented lines in the script indicate, there is some kind of a "null byte" error in the writer. I have tried my best to remove any whitespaces/spaces.
How can this be fixed?
Tags (3)
benberman
Ok, I was able to solve the issue regarding the NUL bytes and the Nonetype keys in the DictWriter. The code works now. Thanks to everyone for your input.
workspace= # path to workspace
file = # path to csv to be read
outfile= # path to csv to be written
input= # path to reference feature_class
with open(file, 'rb') as csvfile:
    with open(outfile,'wb') as f:
        field_names=['Rule','Attribute','Operator','Value','ERROR1',
           'ERROR2','FIXED','Feature Class']
        reader = csv.DictReader(csvfile,field_names,delimiter=',')
        writer=csv.DictWriter(f,field_names)
        for row in reader:
            if None in row:
                del row[None]
                dict_dom={}
                for fld in lstflds:
                for keys,vals in dict_dom.iteritems():
                    if keys == row['Attribute']:
                        v=re.sub(rx,'', str(vals))
                        row['Value']= v.replace('\x00','')
Luke_Pinner
MVP Regular Contributor
Bit hard without the actual error message. Can you add that to your question?
benberman
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 323, in RunScript
    debugger.run(codeObject, __main__.__dict__, start_stepping=0)
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\Pythonwin\pywin\debugger\__init__.py", line 60, in run
    _GetCurrentDebugger().run(cmd, globals,locals, start_stepping)
  File "C:\Python27\ArcGIS10.1\Lib\site-packages\Pythonwin\pywin\debugger\debugger.py", line 655, in run
    exec cmd in globals, locals
  File "C:\tmp\test.py", line 1, in <module>
Error: line contains NULL byte
DanPatterson_Retired
runs in the IDE fine?​
benberman
I'm using pythonwin, yes the whole code executes as expected until it hits the "writerow" line. I tried it without the writerow line and the print statement returned values as expected.
Luke_Pinner
Assuming it's row[3] that contains the NUL, try:
row[3]=v.replace('\x00','')
benberman
hmm...i'm still getting the error..
Lots of links on a search using...
python csv reader line contains null byte
eg.  "Line contains NULL byte" in CSV reader (Python) - Stack Overflow
Did you see any of these?
benberman
I fixed the Null byte problem by using DictReader and DictWriter, but now I am running into a NoneType error when the new spreadsheet is created. The spreadsheet does have empty cells, could this be causing the problem? If so, what's the resolution to this?
outfile=# path to csv to be written
input= # path to reference feature class
        writer.writeheader()
        for row in reader:
            dict_dom={}
            for fld in lstflds:
The error:
self.writer.writerow(self._dict_to_list(rowdict))
  File "C:\Python27\ArcGIS10.1\lib\csv.py", line 144, in _dict_to_list
    ", ".join(wrong_fields))
TypeError: sequence item 0: expected string, NoneType found
benberman
        for row in reader:
            if None in row:
                del row[None]
                dict_dom={}
                for fld in lstflds:
