How to display "Background Processing" messages in Python
2897
05-01-2015 12:19 PM
JoseSanchez
Hello everyone,
When running ModelBuilder if the option "Background Processing" is disabled it shows all the commands executed on the screen.
How can I do the same thing when running a Pytho script or at least when I run the script with IDLE or PyScripter?
the problem when testing a Python script it does not show what is executing
TimWitt2
Jose,
I use the following in my script to keep up with what the code is doing
print '(10% Completed) Copying features from the SDE to the Local Machine'
Tim
curtvprice
Even when things are running in the background,  you can see the messages in the Results window as they are executing (you can click on the little arcmap progress icon to bring up the results window easily, otherwise Geoprocessing > Results will bring it up).
If you are running a Python script as a script tool, "print" will not show up in to GP messages; you need to use the arcpy messaging methods (AddMessage, AddWarning, AddError). And there is always the Progressor methods, which are pretty nifty when running a script in the foreground.
BlakeTerhune
MVP Regular Contributor
I typically use the method Tim Witt  described to just print whatever I want to the Python Interpreter window. If you're using Esri geoprocessing tools, you can also print the original Esri messages with GetMessages (arcpy)​.
