ArcMap with Python
4774
04-29-2015 12:47 PM
MiguelHoyos
I can't import the arcpy module from the Python window. It seems to be a problem with the numpy module. What can i do? I have ArcMap 10.2.2
Tags (3)
SepheFox
What happens exactly when you type import arcpy from the Python window?
MiguelHoyos
>>> import arcpy
Runtime error
  File "<string>", line 1, in <module>
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\__init__.py", line 24, in <module>
    from arcpy.toolbox import *
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\toolbox.py", line 356, in <module>
    from management import Graph, GraphTemplate
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\management.py", line 22, in <module>
    import _management
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\_management.py", line 14, in <module>
    import _graph
  File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\_graph.py", line 27, in <module>
    import numpy
ImportError: No module named numpy
DanPatterson_Retired
not installed properly...​
Which Python window?  The IDE built into arcmap?  Pythonwin? PyScripter?
If it is something other than within ArcMap, then you need to import them explicitly,
>>> import arcpy
>>> import numpy  # if you want to use the namespace numpy
OR
>>> import numpy as np # the usual nickname for numpy​
If neither of these work, your installation is broken and you will need to reinstall.  It is recommended that you let ArcMap install where it wants to.  Also, if you are not familiar with Python, it would be a good idea to uninstall any previous installations that exist on disk, then install ArcMap and reinstall other installations if you know how to work with Python paths etc.  Fixing a Python install can be done, but I don't recommend it. Running a different version on a separate machine is cheaper if you include debug time.
