Ranking values by shape area using ArcPy
3652
04-29-2015 12:10 AM
deleted-user-3rTxRfVTcNm-
I'm trying to make a script that performs the following: it creates a new field that will hold values based on size of the shape area (from 1 to end of table), basically ranking them.
I have a few ideas to do it, and managed to write a script, however it is not working, no errors, nothing.
import arcpy
fc = "D:/M1 Geomatique/Programmation II/Dossier/zones-de-rattachement-des-bureaux-de-vote-en-2014.shp"
try:
    arcpy.AddField_management(fc, "RANG", "INT")
    size_rank = 1
    rows = arcpy.UpdateCursor(fc, ["shape_area"], "D")
    for row in rows:
        row.setValue("RANG", size_rank)
        pop_rank += 1
        rows.updateRow(row)
except:
    arcpy.GetMessages()
Another idea would be to somehow adapt this code, but in any case it is mentioned that shapefiles do not support ORDER BY as used above by arcpy.da.UpdateCursor’s sql_clause argument.
One other idea, to use a list (ListFeatureClasses probably) to get all values, sort them by size, make a loop that takes each value and places a number based on their size. This one seems a bit complicated and I don't have a clear image on how to get through with it.
What would you recommend me to do?
Problem solved.
"INT" isn't a proper value for AddField, and then again fc shouldn't be there anymore after my last modification.
So far, I've done some corrections to it but still not working, not even creation of a new field which I find it odd.
import arcpy
arcpy.env.workspace = "D:/M1 Geomatique/Programmation II/Dossier"
try:
    arcpy.AddField_management("zones-de-rattachement-des-bureaux-de-vote-en-2014", "RANG", "INT")
    size_rank = 1
    rows = arcpy.UpdateCursor(fc, sort_fields="shape_area D")
    for row in rows:
        size_rank += 1
        rows.updateRow(row)
except:
    arcpy.GetMessages()
Problem solved.
