dijit/search widget - not working
6142
04-23-2015 08:38 AM
ShruthiR
I am working on dijit/search widget. I am trying to use to find trees on the feature layer based on Memorial feature.
When I try to search - it says Pagination error /enter a search term.
Not sure what I am missing.
Below is the code I am trying to work on. Can some one please let me know, If I am missing something ?
Unable to find much info on this widget.
<!DOCTYPE html>
<html dir="ltr">
<head>
   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
   <title>ArcGIS API for JavaScript | Basic Search</title>
   <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
   <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
      <script>
      var dojoConfig = {
         parseOnLoad: true
   </script>
   <script src="http://js.arcgis.com/3.13/"></script>
   <script>
      require([
"esri/map","esri/dijit/Search","esri/InfoTemplate","esri/dijit/Popup", "esri/dijit/PopupTemplate", "esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol", "esri/Color", "dojo/dom-class", "dojo/dom-construct", "dojo/on",
"esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/ArcGISTiledMapServiceLayer",
"dojox/charting/Chart", "dojox/charting/themes/Dollar", "esri/InfoTemplate","dojo/domReady!"
      ], function (Map,Search,InfoTemplate, Popup, PopupTemplate, FeatureLayer, SimpleFillSymbol, Color, domClass,
                 domConstruct, on, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, Chart,theme) {
          var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
          var popup = new Popup({
            fillSymbol: fill,
            titleInBody: false
            }, domConstruct.create("div"));
            domClass.add(popup.domNode, "dark");
         var map = new Map("map", {
            center: [-120.435, 46.159], // lon, lat
            zoom: 7,
            infoWindow: popup
         var template = new PopupTemplate({
                    title: "BGSU Memorial Tree",
                    description: " Tree Memorial: {MEMORIAL} <br/>Tree Variety: {TREE_VARIETY} <br/>Tree Species: {TREE_SPECIES} Tree Species <br/> <img src={TLINK}  height =100px  width=100px alt=\"No image to display\" />",
                    //description1:"{TREE_SPECIES }: Tree Species",
                    fieldInfos: [{ //define field information
                        fieldName: "TREE_SPECIES",
                        label: "Type"
                        fieldName: "TREE_VARIETY",
                        label: "Type"
                    mediaInfos: [{ //define the template
                        caption: "",
                        type: "",
                        value: {
                            theme: "",
                            fields: ["TREE_SPECIES", "TREE_VARIETY"]
                var basemap = new ArcGISTiledMapServiceLayer("https://gistest2.bgsu.edu/arcgis/rest/services/Basemap/Basemap/MapServer");
                map.addLayer(basemap);
                // this layer is for tree icons
                var usaLayer = new ArcGISDynamicMapServiceLayer("https://gistest2.bgsu.edu/arcgis/rest/services/MemorialTrees/MemorialTEST/MapServer/", {
                    opacity: 0.7,
                    visible: false
                usaLayer.setVisibleLayers([2]);
                map.addLayer(usaLayer);
                // this is for data to be retrived and show in the template
        var featureLayer = new FeatureLayer("https://gistest2.bgsu.edu/arcgis/rest/services/MemorialTrees/MemorialTrees/MapServer/0", {
                    mode: FeatureLayer.MODE_ONDEMAND,
                    outFields: ["MEMORIAL", "TREE_VARIETY", "TREE_SPECIES", "TLINK"],
                    infoTemplate: template
                map.addLayer(featureLayer);
                // search widget
                var search = new Search({
                 map: map,
                 sources: [],zoomScale: 5000000}, "search");
                  //listen for the load event and set the source properties
         search.on("load", function () {
            var sources = search.sources;
            sources.push({
               featureLayer: featureLayer,
               placeholder: "Search Memorial Trees",
               enableLabel: false,
               searchFields: ["MEMORIAL"],
               displayField: "MEMORIAL",
               exactMatch: false,
               outFields: ["MEMORIAL", "TREE_SPECIES", "TREE_VARIETY"]
            //Set the sources above to the search widget
            search.set("sources", sources);
         search.startup();
   </script>
</head>
<body>
   <div id="search"></div>
   <div id="map"></div>
</body>
</html>
Thanks!
RobertScheitlin__GISP
Shruthi,
  There is a bug in the current Search Widget that has to be worked around by adding maxResults and setting it to a string. This workaround is discussed here:
Search: "Pagination is not supported."
        sources.push({
          enableLabel: false,
          exactMatch: false,
          outFields: ["MEMORIAL", "TREE_SPECIES", "TREE_VARIETY"],
          maxResults: "Foo"
Shruthi,
        sources.push({
          enableLabel: false,
          exactMatch: false,
          maxResults: "Foo"
ShruthiR
Thank you very much, it worked!
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
