Accessing REST service on an Instance
959
10-18-2010 04:41 AM
TolgaOnakya
We are trying to access the rest services on one of our instances but get the following error below. I did run a Post install several times but it is still inaccessible. We have no issues accessing "manager" for this instance.  We have 2 instances that are currently running on our GIS server. One of the instances, we can access Rest, but in our 2nd instance we can't. The configurations (IIS authentication and security) are identical for both instances. I just don't know why we can not access this instance.
Any assistance would be appreciated.
Server Error in '/"2nd instance name"/rest' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
    <system.web>
        <customErrors mode="Off"/>
    </system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
    <system.web>
        <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
    </system.web>
</configuration>
