Add Bing Hybrid into WAB Basemap Gallery
3052
04-15-2015 11:42 PM
KevinHatch
I would like to add Bing Maps as a base map using the WAB Basemap Gallery Widget.  Currently I have added it to my web map via AGOL.  When referencing that map in WAB it loads with that base map intact and it is part of my gallery.  However, this requires that the Bing Hybrid loads as default at start up.  It also makes it a pain to manage my web map as I have to remember to add Bing each time before saving.
is there a way to add it directly to the basemap gallery in WAB?
StanMcShinsky
Kevin Hatch​,
I am not sure if Bing is different but you could create a blank AGOL map with the bing added as a basemap and save it in a "basemaps" group in your organization. Then in the organization settings under map > basemap gallery you can select the "basemaps" group created and click save. This should add it to the basemap gallery in all organization web maps including WAB.
-Stan
StanMcShinsky
Kevin Hatch​,
-Stan
KevinHatch
That works brilliantly.  Thanks!!!
