calculate # of features with distance and time constraints
6876
11
04-13-2015 03:21 PM
QiuhuaMa
Earlier I asked how to find the nearest fire that burned 7 years ago and get helped.
Here is the detail the discussion:
https://community.esri.com/message/491873?et=watches.email.thread#491873
Another way to check the effect of fire on house is to count number and size of fire within a certain distance in the last 7 years.
For example, I want to find number of fires within 5km of each house in the past 7 years, then calculate their average size!
How to code this in Python?
My sample data is attached. SHAPE_AERA is the size of fire.
Thanks so much,
Chelsea
XanderBakker
Esri Esteemed Contributor
I guess I should have read you question better... there is no distance tolerance for the fires. However this is relatively easy to do. See the code below. I just did a run, but less than 200 house have at most a single fire within a distance of 5km. I am running a test with 25km to check the results.
Code:
  • The search distance can be specified on line 61
  • Since your data uses foot as linear unit and your search distance is metric, line 62 contains the conversion from feet to meter
  • Line 102 checks to see if the distance is within the search distance
  • minimum distance and oid of nearest fire is provided anyway.
  • To make it faster you could make a selection (select by location) of the fires that are with the search distance and use that as input.
import arcpy
from datetime import datetime, date, timedelta
from dateutil.relativedelta import relativedelta
def main():
    # input fc's
    fc_house = r"D:\Xander\GeoNet\DistFireHouse\shp\housesaledata.shp"
    fc_fire = r"D:\Xander\GeoNet\DistFireHouse\shp\firehistory_NAD_fips3002_feet.shp"
    # input field
    fld_date_sale = "ma_date_dt"
    # output fields
    fld_dist = "Dist2Fire"
    fld_fire_oid = "FireOID"
    # additional fields
    fld_FireMinArea = "FireMinAr"
    fld_FireMaxArea = "FireMaxAr"
    fld_FireMeanArea = "FireMeanAr"
    fld_FireCount = "FireCount"
    # add fields
    addField(fc_house, fld_dist, "DOUBLE")
    addField(fc_house, fld_fire_oid, "LONG")
    # add additional fields
    addField(fc_house, fld_FireMinArea, "DOUBLE")
    addField(fc_house, fld_FireMaxArea, "DOUBLE")
    addField(fc_house, fld_FireMeanArea, "DOUBLE")
    addField(fc_house, fld_FireCount, "LONG")
    # loop through houses
    cnt = 0
    flds = ("SHAPE@", fld_date_sale, fld_dist, fld_fire_oid, fld_FireMinArea,
            fld_FireMaxArea, fld_FireMeanArea, fld_FireCount)
    with arcpy.da.UpdateCursor(fc_house, flds) as curs:
        for row in curs:
            cnt += 1
            if cnt % 25 == 0:
                print "Processing house: {0}".format(cnt)
            pnt = row[0]
            date_sale = row[1]
            results = getNearestFireAndAreaStats(fc_fire, pnt, date_sale)
            row[2] = results[0] # dist nearest
            row[3] = results[1] # oid nearest
            row[4] = results[2] # Min Area
            row[5] = results[3] # Max Area
            row[6] = results[4] # Mean Area
            row[7] = results[5] # Count Fires
            curs.updateRow(row)
def addField(fc, fldname, fldtype):
    if len(arcpy.ListFields(fc, wild_card=fldname)) == 0:
        arcpy.AddField_management(fc, fldname, fldtype)
def getNearestFireAndAreaStats(fc, pnt, date_sale):
    # maximum distance for fire
    search_dist = 5000.0 # meters
    ft_to_m = 0.30480061 # conversion feet to meter
    # input fields
    fld_year = "FIRE_YEAR"
    fld_month = "FIRE_MONTH"
    fld_day = "FIRE_DAY"
    fld_area = "SHAPE_AREA"
    # defaults
    min_dist = 999999
    oid_fire = -1
    min_area = 9999999999
    max_area = 0
    sum_area = 0
    mean_area = 0
    cnt_fires = 0
    # results
    res = []
    flds = ("SHAPE@", "OID@", fld_year, fld_month, fld_day, fld_area)
    with arcpy.da.SearchCursor(fc, flds) as curs:
        for row in curs:
            polygon = row[0]
            oid = row[1]
            year = int(row[2])
            try:
                month = int(row[3])
            except:
                month = 6
            try:
                day = int(row[4])
            except:
                day = 15
            if chkDate(date_sale, year, month, day):
                # these are the fires we are looking for
                dist = pnt.distanceTo(polygon)
                if dist < min_dist:
                    min_dist = dist
                    oid_fire = oid
                if (dist * ft_to_m) < search_dist:
                    area = row[5]
                    if cnt_fires == 0:
                        min_area = area
                        max_area = area
                        sum_area = area
                    else:
                        if area < min_area: min_area = area
                        if area > max_area: max_area = area
                        sum_area += area
                    cnt_fires += 1
    if cnt_fires > 0:
        mean_area = sum_area / float(cnt_fires)
    else:
        min_area = 0
    return [min_dist * ft_to_m, oid_fire, min_area, max_area, mean_area, cnt_fires]
def chkDate(date_sale, year_fire, month_fire, day_fire):
    date_fire = datetime(year=year_fire, month=month_fire, day=day_fire)
    date_2monthsbefore_sale = date_sale + relativedelta(months=-2)
    year_sale = date_sale.year
    test = (year_fire >= year_sale - 7) and (date_fire < date_2monthsbefore_sale)
    return test
if __name__ == '__main__':
    main()
XanderBakker
Hi Qiuhua Ma ,
Have a look at the changed code below. To run it, make sure you reference your shapefiles on lines 07 and 08.
Changes are:
  • additional output field names (lines 17 to 21)
  • adding the additional fields (lines 27 to 31)
  • on line 35 and 36 add the fields to the list of fields used in the cursor
  • line 44 calls a function getNearestFireAndAreaStats (defined on line 58) which replaces the function getNearestFire. This new function returns a list with 6 results.
  • Lines 45-50 reads the results and sets them to the current row
  • On line 58 the function getNearestFireAndAreaStats starts:
    • additional variables on lines 67 - 71
    • lines 92 - 101 determines the min, max, sum and count of the relevant fires
    • line 108 - 109 calculates the mean area (if there are fires found)
    • line 110 returns the list of results for the current house
import arcpy
def main():
    # input fc's
    # input field
    # output fields
    # additional fields
    # add fields
    cnt = 0
        for row in curs:
            cnt += 1
            if cnt % 25 == 0:
            pnt = row[0]
            date_sale = row[1]
            curs.updateRow(row)
    # input fields
    # defaults
    min_dist = 999999
    oid_fire = -1
    max_area = 0
    sum_area = 0
    mean_area = 0
    cnt_fires = 0
    # results
    res = []
    flds = ("SHAPE@", "OID@", fld_year, fld_month, fld_day)
        for row in curs:
            polygon = row[0]
            oid = row[1]
            year = int(row[2])
            try:
                month = int(row[3])
            except:
                month = 6
            try:
                day = int(row[4])
            except:
                day = 15
                if cnt_fires == 0:
                    min_area = polygon.area
                    max_area = polygon.area
                    sum_area = polygon.area
                else:
                    if polygon.area < min_area: min_area = polygon.area
                    if polygon.area > max_area: max_area = polygon.area
                    sum_area += polygon.area
                cnt_fires += 1
                if dist < min_dist:
                    min_dist = dist
                    oid_fire = oid
    if cnt_fires > 0:
    return [min_dist, oid_fire, min_area, max_area, mean_area, cnt_fires]
    return test
    main()
QiuhuaMa
Xander,
Thanks so much! however I cannot see which line restrict distance, # of
fires and average size of fires within 5kms of a house in the past 7 years!
Qiuhua
XanderBakker
Code:
import arcpy
def main():
    # input fc's
    # input field
    # output fields
    # additional fields
    # add fields
    cnt = 0
        for row in curs:
            cnt += 1
            if cnt % 25 == 0:
            pnt = row[0]
            date_sale = row[1]
            curs.updateRow(row)
    # input fields
    # defaults
    min_dist = 999999
    oid_fire = -1
    max_area = 0
    sum_area = 0
    mean_area = 0
    cnt_fires = 0
    # results
    res = []
        for row in curs:
            polygon = row[0]
            oid = row[1]
            year = int(row[2])
            try:
                month = int(row[3])
            except:
                month = 6
            try:
                day = int(row[4])
            except:
                day = 15
                if dist < min_dist:
                    min_dist = dist
                    oid_fire = oid
                    area = row[5]
                    if cnt_fires == 0:
                        min_area = area
                        max_area = area
                        sum_area = area
                    else:
                        sum_area += area
                    cnt_fires += 1
    if cnt_fires > 0:
    else:
        min_area = 0
    return test
    main()
QiuhuaMa
Yes, you are right! Most houses in my data are located in the city and far
away from the fires. With 25km, 70% of the houses should have more than one
fire!
Qiuhua
XanderBakker
Indeed it look a lot more dramatic if the search distance is raised to 25km:
By Count:
By Mean Area:
BTW, if your question has been answered, please mark the correct answer. If any post was helpful, you can also mark it as such
QiuhuaMa
Xander,
I am a little confused about dist2fire and fireoid. They refer to the
nearest fire burned in the past 7 years or the nearest one burned within 5
kms in the last 7 years?
thanks,
qiuhua
XanderBakker
Hi Qiuhua Ma ,
The min_dist (Dist2Fire) and oid_fire (FireOID) are still the same as before. They represent to distance to and oid of the nearest fire. I left it in since for each fire polygon that if within the date range the distance is calculated (the variable dist on line 98). This distance "dist" is used to see if it is within the search tolerance. If it is, the fire is considered for the area and count statistics.
Indifferent of the search tolerance the minimum distance is registered. So, you will see cases (houses) that will have a count of 0 fires, but do have info on the nearest fire. You will also see that in those cases the distance (minimum distance) will be higher than the search tolerance specified on line 61 (search_dist).
For the specific question in this thread, you could ignore the output fields "Dist2Fire" and "FireOID". The relevant fields will be "FireMinAr", "FireMaxAr", "FireMeanAr" and "FireCount".
Hope this makes it a little clearer...
Kind regards, Xander
QiuhuaMa
Xander,
is there a problem with the code?
I want to calculate number of fires and average size of fires within 5km of a houses in the past 7 years. I saw that number of fire is 1 but max, min and average size of fire is 0.
if there is only one fire, these sizes should be the size of that fire, right?
XanderBakker
Are those results based on the dataset you posted earlier or are you using  new set of data? If so please post a sample of this data to be able to reproduce the problem.
