Extract ArcGIS Server map/geodata service data to local GDB using Python and .bat file
3817
04-10-2015 10:31 AM
AndrewNiederhauser1
I'm looking to extract the data from a map/geodata service to a local SQL Server Geodatabase using a series of Python and .bat files. I would think the process would involve a Python script to create a replica from the REST endpoint then use Python again to export that replica to the SQL GDB. Has anybody attempted this before or have any suggestions on where to start?
Andrew
AndrewBrown
AndrewBrown
Never done it, but I'd start
here
Geodata service usage
http://resources.arcgis.com/en/help/main/10.2/0154/015400000335000000.htm
and here
An overview of the Distributed Geodatabase toolset
http://resources.arcgis.com/en/help/main/10.2/0017/001700000013000000.htm
