No feature table Type - runtime content
4908
04-09-2015 08:51 PM
PremRadhakrishnan
I am trying to add a layer from a local geodatabase file that was created using ArcMap. I have tried two different files ( .geodatabase format ) that my analyst generated for me and in both cases. I am getting the following errors.
The files are kinda big to attach but I will be glad to send it directly via email.
I am using Desktop 10.2.2, QT 5.4.1 and ArcGIS QT SDK 10.2.5
ArcGIS.Runtime.Map: void __cdecl QmlMap::classBegin(void)
ArcGIS.Runtime.Layer: void __cdecl QmlFeatureLayer::setFeatureTable(class QmlFeatureTable *) QObject(0x0)
ArcGIS.Extras.Plugin: class QObject *__cdecl ArcGISExtrasPlugin::systemProvider(class QQmlEngine *,class QJSEngine *) QObject(0x0)
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) devicePixelRatio 1
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) primaryScreen.physicalDotsPerInch 102.299
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) primaryScreen.logicalDotsPerInch 96
ArcGIS.Extras.Core: __cdecl TkSystem::TkSystem(class QObject *) referenceDotsPerInch 96
ArcGIS.Runtime.Utility: class QString __cdecl FileUtility::pathVariable(const class QString &,const class QString &,bool) Setting default "HOME" = "C:/Users/Prem"
ArcGIS.Extras.Core: class QString __cdecl TkSystem::userHomePath(void) Default: "C:/Users/Prem"
ArcGIS.Extras.File: __cdecl TkFileFolder::TkFileFolder(const class QString &,class QObject *) QDir( "C:/Users/Prem" , nameFilters = { * }, QDir::SortFlags( Name | IgnoreCase ) , QDir::Filters( Dirs|Files|Drives|AllEntries ) )
ArcGIS.Runtime.Geodatabase: void __cdecl QmlGeodatabase::setPath(const class QString &) "C:/Users/Prem/ArcGIS/Runtime/bartholomewin_vec.geodatabase" "C:/Users/Prem/ArcGIS/Runtime/bartholomewin_vec.geodatabase"
ArcGIS.Runtime.Map: void __cdecl QmlMap::componentComplete(void)
ArcGIS.Runtime.Map: void __cdecl QmlMap::componentComplete(void) Adding 1 declared layer(s)
ArcGIS.Runtime.Layer: void __cdecl QmlLayer::onLayerCreateError(const class QString &) QmlFeatureLayer "" "No feature table type"
int __cdecl main(int,char *[]) ApplicationWindow_QMLTYPE_12_QML_15(0x1cf26b4180)
The code is really simple
import QtQuick 2.3
import QtQuick.Controls 1.2
import ArcGIS.Runtime 10.25
import ArcGIS.Extras 1.0
ApplicationWindow {
    width: 800
    height: 600
    title: "TestingLocalGDB"
    property string runtimePath: System.userHomeFolder.filePath("ArcGIS/Runtime");
    Geodatabase {
        path: runtimePath + "/bartholomewin_vec.geodatabase" ;
    Map {
        anchors.fill: parent
        focus: true
        ArcGISTiledMapServiceLayer {
            url: "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"
        FeatureLayer {
            featureTable: geodatabase.geodatabaseFeatureTableByLayerId(0);
LucasDanzinger
Esri Frequent Contributor
Prem-
Can you email me the geodatabase ([email protected])? If it is too large, can you put it on some FTP site (or something similar) for me to download?
Also, what version of Desktop was used to produce the geodatabase?
Luke
LucasDanzinger
Prem-
Luke
PremRadhakrishnan
Lucas,
I am not exactly sure what I changed but I created a new project and put the files in the Runtime folder again and was able to get the layers loaded.
I have another question regarding this, is there anyway to view the content other than through a program created using runtime? i.e. Anyway for the person creating the content to check to make sure that the content was created correctly?
Regards,
Prem
LucasDanzinger
Prem-
There's no official application to verify the creation was successful. You may consider making a little runtime application for them that just pops up a file dialog, and they can browse to a geodatabase. It could then iterate through the tables, create feature layers, and add them to a map with a tiled map service in the background.
Luke
