Add a circle to graphics layer
905
10-07-2010 08:08 AM
AndrewEgleton
Is there an easy way to add a circle of known radius to the graphics layer with out using a geometry service task? I'd like to show a ring 400m from the GPS location, which shouldn't be too hard as the spatial reference is in metres already.
Andy
DiveshGoyal
Unfortunately, no. You can use the GeometryService task to buffer a point by 400 m (or whatever distance you want). This will yield a polygon that looks like a circle.
If you don't want to use the GeometryService, you can use a little trigonometry to find the points along the circle's circumference.
Let r be the radius of the circle. Let (a,b) be the center of the circle. Then to find points (x,y) along the circle :
x = a + r*cos(theta)
y = a + r*sin(theta)
Vary theta from 0 - 360. Use small increments to get a more detailed circle.  Create a polygon with a single ring that contains all these (x,y) pairs. You have a circle.
