How to raise exception from if statement in Python
29901
5
04-03-2015 08:19 PM
GeoffreyWest
This is a general python question, I would like to write a function that essentially states if data is available do this, if not raise an error, and a finally block which does something else.
In another function I would like write another if statement that says if function 1 raised an error do this, if not then do this.
My question is, how do I reference this raised user-defined exception from my first function?  Here is a code-block that I am working with.
For example, if there is a raised error for NoData, I would like to say in another function, if NoData is raised then do this....
This block returns:
  File "C:/Users/Administrator/Desktop/DevSummitJSON_PySeminar.py", line 231, in <module>
    servicequery(CreatedDate, now_minus_10)
  File "C:/Users/Administrator/Desktop/DevSummitJSON_PySeminar.py", line 227, in servicequery
    raise DataError, "Exception: Data is older than 10 minutes"
__main__.DataError: Exception: Data is older than 10 minutes
# severely edited, since improper indentation etc, precludes providing a test environment
import arcpy    # not in original
arr = #####     # not in original
fc = ####        # not in original
sr = ####       # not in original
NumPyArray = arcpy.da.NumPyArrayToFeatureClass(arr, fc, ['longitudeshape', 'latitudeshape'], sr)
i = 5
i2= 10
now_minus_5 = Start - datetime.timedelta(minutes =i)
now_minus_10 = Start - datetime.timedelta(minutes =i2)
class DataError(Exception):
  pass
class NoDatainLast5(Exception):
  message = '\nException: NumberTooBigError:\nYour number is too big. \nTry a smaller one!'
class NoDatainLast10(Exception):
def checkData(CreatedDate):
  if CreatedDate > now_minus_10:
    raise NoDatainLast10
  elif CreatedDate > now_minus_10:
    raise NoDatainLast5
  elif CreatedDate is NULL :
    raise DataError
def servicequery(CreatedDate, now_minus_10):
    NumPyArray  #see at the top
  elif CreatedDate < now_minus_10:
  else:
    print "test"
Message was edited by: Dan Patterson I had to reformat the whole script due either to an incorrect format selection or source code was wrong. Added lines at the top of the code to facilitate testing using the edited script.
Luke_Pinner
MVP Regular Contributor
Not quite sure what you are trying to do, but maybe a try: except: block will do what you want?
try:
except DataError as err:
     print 'Data error', err.message
except (NoDatainLast5, NoDatainLast10) as err:
     print 'NoData', err.message
except Exception as err:
     print 'Something else went wrong', err.message
finally:
    print 'Clean up etc...'
SepheFox
It seems like there is a problem with your indentation. Subsequent lines after the If and elif statements should be indented, shouldn't they?
DanPatterson_Retired
Geoffrey
I had to severely edit the code due to formatting errors.  Please correct any lines that I may have mis-corrected
Dan
GeoffreyWest1
Thanks Dan,
I think I have been able to solve this with a return statement instead of raise.
curtvprice
A single exception class can be used to trap all your errors and print your message. I think this is a lot less work.
class MsgError(Exception):
    pass
try:
        raise MsgError("Your number is too big. \nTry a smaller one!")
except MsgError as msg:
    arcpy.AddError(msg)
except Exception as msg:
    arcpy.AddError("Python error:\n" + msg)
