Is there a way to cancel Editor.RequestShapeAsync?
4669
04-03-2015 02:06 PM
AshleyDePottey
Is there any way to gracefully cancel the RequestShapeAsync task?  I do not have much experience with using the C# async capabilities, but it seems the awaitable method needs to accept a cancellation token and this method does not appear to accept one.  Is there any other way to cancel this method gracefully?  For example, if a user is in the middle of drawing a polygon does not want to finish it, I need a way to cancel this task by clicking a cancel button.
AsserSwelam1
Hi Ashley,
You can check if the Editor is active and if yes you can use Cancel.Execute.
if (MyMapView.Editor.IsActive)
  MyMapView.Editor.Cancel.Execute(null);
-Asser
AsserSwelam1
Hi Ashley,
-Asser
AshleyDePottey
Thanks Asser!  That worked perfectly.
