Modify Renderer of FeatureLayer
6007
6
04-02-2015 03:14 PM
AndyWright
I am trying to modify the renderer on a FeatureLayer from a local geodatabase and have not had much success.  I can see my modifications to the renderer when I console.log its json, but the changes do not get applied to the layer in the map.  FeatureLayer does not have a refresh like dynamic map layers do, so I'm not sure how to update the layer in the map so it reflects the changes I made to the renderer.   I have included my code below.  Does anyone have any ideas?
import QtQuick 2.3
import QtQuick.Controls 1.2
import ArcGIS.Runtime 10.25
import ArcGIS.Extras 1.0
ApplicationWindow {
    width: 800
    height: 600
    title: "SmallSymbolFix"
    property string m_LocalDataPath: System.userHomeFolder.path + "/Documents"
    Map {
        anchors.fill: parent
        wrapAroundEnabled: true
        ArcGISTiledMapServiceLayer {
            url: "http://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer"
        onStatusChanged: {
           if (status === Enums.MapStatusReady)
              damageGdb.path = m_LocalDataPath + "/EpochField/Data/DamageAssessment/WorkAssignments.geodatabase"
        FeatureLayer {
            featureTable: featTab
            onStatusChanged: {
                if (status === Enums.LayerStatusInitialized) {
                    var newRenderer = ArcGISRuntime.createObject("UniqueValueRenderer");
                    var oldRenderer = featLyr.renderer;
                    for (var l = 0; l < oldRenderer.uniqueValues.length; ++l) {
                        var newSym = ArcGISRuntime.createObject("PictureMarkerSymbol");
                        newSym = oldRenderer.uniqueValues.symbol
                        newSym.height = 40;
                        newSym.width = 40;
                        var newUVI = ArcGISRuntime.createObject("UniqueValueInfo");
                        newUVI = oldRenderer.uniqueValues;
                        newUVI.symbol = newSym;
                        //console.log("\n\nNEW SYMBOL: " + JSON.stringify(newSym.json));
                        newRenderer.addValue(newUVI);
                    featLyr.renderer = newRenderer;
                    console.log("\n\nNEW RENDERER: " + JSON.stringify(newRenderer.json));
    Geodatabase {
        onValidChanged: {
            if (valid) {
                //  Add feature layer to map
                var gdbFeatTab = geodatabaseFeatureTable("Work Assignment");
                var operLayer = ArcGISRuntime.createObject("FeatureLayer");
                operLayer.featureTable = gdbFeatTab;
                appMap.addLayer(operLayer);
    GeodatabaseFeatureTable {
        geodatabase: damageGdb.valid ? damageGdb : null
        featureServiceLayerName: "Work Assignment"
        onGeodatabaseFeatureTableValidChanged: {
            if (geodatabaseFeatureTableValid) {
                console.log("Work Assignment feature table is initialized ...")
LucasDanzinger
Esri Frequent Contributor
Hey Andy,
Yes, that should work as well. I think the main issue with your code is that you aren't setting the attributeNames on the feature layer's new renderer. Check out the example below and see if you can get that working in your app.
-Luke
import QtQuick 2.3
ApplicationWindow {
    width: 800
    height: 600
    Map {
        FeatureLayer {
            featureTable: featureServiceTable
    Button {
        anchors {
            left: parent.left
            top: parent.top
            margins: 15
        text: "change renderer"
        onClicked: {
            var orig_info_List = featLyr.renderer.uniqueValues;
            var new_renderer = ArcGISRuntime.createObject("UniqueValueRenderer", {attributeNames: featLyr.renderer.attributeNames});
            for (var i = 0; i < orig_info_List.length; ++i) {
                //create the new symbol
                var symbol = orig_info_List.symbol;
                symbol.width = 40;
                symbol.height = 40;
                //create the new UniqueValueInfo
                var newInfo = ArcGISRuntime.createObject("UniqueValueInfo");
                newInfo = orig_info_List;
                newInfo.symbol = symbol;
                new_renderer.addValue(newInfo);
            featLyr.renderer = new_renderer;
    GeodatabaseFeatureServiceTable {
        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/DamageAssessment/FeatureServer/0"
LucasDanzinger
Hey Andy-
In general, it can be done. Here is a simplified version of your code that uses the DamageInpsection geodatabase that comes with the sdk. I can switch it over to use a simple marker symbol.
import QtQuick 2.3
ApplicationWindow {
    width: 800
    height: 600
    Map {
        FeatureLayer {
    Button {
        anchors {
            left: parent.left
            top: parent.top
            margins: 15
        onClicked: {
            var newRenderer = ArcGISRuntime.createObject("SimpleRenderer");
            newRenderer.symbol = ArcGISRuntime.createObject("SimpleMarkerSymbol", {color: "blue", size: 25});
    Geodatabase {
        path: "C:/temp/DamageInspection6.geodatabase"
        featureServiceLayerId: 0
AndyWright
HI Lucas,
Thanks for the reply.  When you say in general does that mean it can only be done for simple renderers?  Can I do this with unique value renderers?  Can I modify the layer's existing renderer or does it just work when you create something from scratch?
I feel like I'm very close as I can see my symbol modifications in the json for the new renderer, I just can't figure out how to apply that new renderer to the feature layer.
LucasDanzinger
Hey Andy,
-Luke
import QtQuick 2.3
ApplicationWindow {
    width: 800
    height: 600
    Map {
        FeatureLayer {
    Button {
        anchors {
            left: parent.left
            top: parent.top
            margins: 15
        onClicked: {
                symbol.width = 40;
                symbol.height = 40;
AndyWright
The attributeNames property was the missing piece.  Thanks for your help Lucas!
albavoli
i am using the same example but instead of a simple mark symbol i wanna add a picture one but doesnt refrect on the layer it just shows a red circle marker not the image :
    newRenderer.symbol = ArcGISRuntime.createObject("PictureMarkerSymbol", {url: "RedShinyPin.png"});
  layer.renderer = newRenderer;
what might be the problem?
LucasDanzinger
The code looks fine and should work no problem. Maybe it can't find the PNG? Try giving it an online URL like this just to make sure that isn't the problem - http://static.arcgis.com/images/Symbols/AtoZ/redB.png
