Geolocate
5676
04-01-2015 02:28 PM
StanMcShinsky
Is there a way to make the MyLocation widget stay on so that it will follow you around as you are moving?
-Stan
RobertScheitlin__GISP
Stan,
   Sure just add "useTracking": true to the locateButton object in the config.json for the myLocate widget.
So the config.json will look like this:
  "locateButton": {
    "geolocationOptions": {
      "timeout": 15000
    "highlightLocation": true,
    "useTracking": true
Stan,
  "locateButton": {
      "timeout": 15000
    "useTracking": true
StanMcShinsky
Thanks Robert I knew there was a parameter to add but I could not find it right off.
williamcarr
Is there a way to toggle this on and off?
William,
   Sure you just click the locate button again to turn it off, just like the standard LocateButton dijit in the JS API.
