Data Frame Coordinates have changed to Decimal Degrees
5026
03-26-2015 01:46 PM
GavinMayeda
I have a crazy issue, and I am not quite sure how to fix this.  Data frame coordinates have changed to decimal degrees, and I want to change it back to the default spheroid data.  How do I do this?
DanPatterson_Retired
The default is in the coordinate system of the first file added to the data frame.  By any chance are the files you using have unknown coordinate systems?
right-click in the data frame and select properties, you can set all the properties there
GavinMayeda
Thanks Dan,
I should have put a bit more information out there...........
I did go in to the data frame properties, and nothing I did would change the coordinate display back to default. I also tried using the Customize and that didn't help, nor did the editing options................
I did remember to stop any editing, so that isn't the issue either......
GavinMayeda
I think you hit the nail on the head Dan.  I was working on a feature when I brought in a basemap from ESRI's library.  That is when the dataframe coordinates changed.  I brought in a different feature and the coordinates are right.  Thanks a ton!!
