Show a graph with python
8382
5
03-22-2015 09:16 PM
Warwick
Using the GP tools and python it is possible to dynamically create a graph in ArcMap but how can I display the graph to the user?
NeilAyres
Regardless of how the graph is made, either manually or via a script, I think you still have to open the graph in ArcMap.
View / Graph and then pick it.
If you are creating the graph using arcpy / python, is this happening within an open ArcMap mxd?
JamesCrandall
Yes it is possible.  It's probably not as straight-forward as you might be expecting though.  For our implementation(s), we employ the matplotlib library to generate our graphs, save as .png and then populate File Geodatabase(s) as attachments to their related FeatureClasses.
I couldn't really begin to post up any code examples unless you have something specific in mind. Post up an example of your data.
Warwick
Workflow would be as follows. User has an ArcMap document open in which a NetCDF Raster layer is visible. The user clicks on a location to view how a variable changes over time or levels. All the steps can be scripted using python, GP tools and a graph template except for the final step of displaying the graph to the user. Am I missing something?
JamesCrandall
Here's a short example using matplotlib (although there are probably far better examples found with a quick Google search or on Stack Overflow).
Sample data:
H:\GraphData.csv
    Month  Values
0       1  2.0228
1       2  2.0229
2       3  2.0231
3       4  2.0232
4       5  2.0233
5       6  2.0234
6       7  2.0235
7       8  2.0236
8       9  2.0237
9      10  2.0237
10     11  2.0238
11     12  2.0239
12     13  2.0240
13     14  2.0241
14     15  2.0243
15     16  2.0244
16     17  2.0247
17     18  2.0247
18     19  2.0248
19     20  2.0249
20     21  2.0250
21     22  2.0250
22     23  2.0252
23     24  2.0253
py Code:
import pandas as pd
from pandas import *
import matplotlib.pyplot as plt
data = r'H:\GraphData.csv'
df = pd.io.parsers.read_table(data, sep=',')
xs = df.Month
ys = df['Values']
min = df['Month'].min()
max = df['Month'].max()
fig = plt.figure()
ax = "ax" + str(211)
ax = fig.add_subplot(211, axisbg='white')
ax.plot(xs, ys, linestyle='-', marker='', linewidth=1, color='blue', label=str('Graph Test'))
plt.savefig(r'H:\GraphData.png', dpi=600)
plt.close()
del fig
XanderBakker
Esri Esteemed Contributor
I posted a document a while ago with an example of creating a profile graph with matplotlib:
Using Python and matplotlib to create profile graphs
Dan Patterson​ has some valuable posts on this topic too:
Collections in numpy: producing frequency distributions and graphing​and X-Y graphing demo using pyplot (matplotlib)...an introduction
