Points to Polygons Spatial Join Fails
4984
03-22-2015 02:11 PM
FatmaŞenol
Hello Geonet Members,
I've been using ArcGIS for a long time but I never encountered such a problem before.
I have a polygon layer showing buildings (26525 polygons) and a point layer which
has land-use information of a part of the buildings (299 points).
Please note that each point falls inside the associated polygon. I simply performed spatial
join and  expected that each polygon representing buildings would be given all the attributes of
the point. However, all buildings  were given all the attributes of the points not only 299 buildings.
I repeated the same procedure for several times but ended up with no luck.
I would appreciate if you could kindly share your suggestions. Thank you in advance.
Best Regards
- O. Saygin
DanPatterson_Retired
Without relying on visuals, can you confirm the coordinate system by looking at it AND each layers extents to ensure that one or the other has not been inappropriately defined?
Also try an Intersect to see what that does (intersect the points with the polygons)
FatmaŞenol
Hello Dan,
Thank you for your comment and suggestion. The coordinate system of both layers
is same which is WGS 1984 Zone 35 N. I also checked each layer's extents and
found that they are different. I'm not so clear but are you saying extents of both
layers should be the same ?
I tried to intersect the points with the polygons but I got two error messages;
1) `The table was not found.`
2) ` Invalid Topology [Z coord limit exceeded.]
      Failed to execute (Intersect)
Regards
- O.Saygin
when I mean the extents being the same, I mean that one layer is inside or intersects with another.  This will be obvious if one layer doesn't even overlap the other as would be the case when one file is in UTM coordinates and the other in decimal degrees EVEN though both are defined as UTM.  So, if they don't overlap/Intersect then something is amiss.  Which Is why I suggested using the Intersect tool in ArcToolbox since you can produce a point file and optionally carry over the polygon attributes
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
