Dynamic text
4631
03-20-2015 09:48 AM
WarrenMedernach
Is the Dynamic Text functionality 'fully baked' yet in Pro?
I have found very few of the tags that actually work?
Screen capture #1 shows the list of Dynamic Text and evens shows the appropriate value, ie Credits property.  But as you can see in screen cap #2, when this is inserted the actual value is blank.  This is the case with many of the tags I've tried, but I'm wondering if this is an artifact of importing a MXD project?
Warren
DavidBarnes
One thing to try: the bounding box may not be big enough, thereby dropping some of the text. See if expanding the bounding by dragging a handle box helps.
WarrenMedernach
After further investigation, I think this is an issue with this particular MXD I Imported, or maybe an issue with the Map Import function.  I started another blank project and used Import Layout, instead of Import Map, and the Dynamic Text commands are working as expected in this project.
Warren
