Open side panel at start
9508
12
03-18-2015 11:05 AM
SébastienMartin
On a web app created with webapp builder, how can I make the legend on the sidebar open at start?
I tried to insert this in \widgets\Legend\config.json
"openAtStart": true
It's not working... Any idea?
Full config.json :
  "legend":{
    "arrangement": 0,
    "autoUpdate": true,
    "respectCurrentMapScale": true,
    "openAtStart": true
StanMcShinsky
I have tested this and it works great for me. Did you try to add the "openAtStart": true, to the main config file in the root of the application NOT in the \widgets\Legend\config.json? This config.json file is at the same level as your index.html file.
By the way, if you notice for the legend widget, the main config file does not even reference a legend config file by default.
        "uri": "widgets/Legend/Widget",
        "version": "1.1",
        "id": "widgets/Legend/Widget_13",
        "index": 2,
        "name": "Legend",
        "label": "Legend"
If you change a default attribute for the widget then it will create a new config file in configs/Legend/config_Legend.json and add the line of code to reference that new config.
        "version": "1.1",
        "index": 2,
        "name": "Legend",
        "label": "Legend",
        "config": "configs/Legend/config_Legend.json"
Add the "openAtStart": true to this file in the Legend widget and it should work. If not then try clearing your browser cache and reload.
As I am looking at this I realize that this works for the default Foldable Theme and not for the Tab Theme. Is that the issue you are having?
For the Tab Theme here is how to get the side panel to open at start:
in the file: \themes\TabTheme\widgets\SidebarController\widget.js
make this one change on about line 61
      startup: function() {
        this.inherited(arguments);
        this.createTabs();
        //this.widgetManager.minimizeWidget(this);
        this.widgetManager.maximizeWidget(this);//changed this
This maximizes the side panel at startup. Not sure how to tell it what widget to open first, but if you put the one you want open at the top then it will load in first.
-Stan
KellyHutchins
Esri Notable Contributor
You might want to post WAB questions to the Web AppBuilder for ArcGIS​ space in order to reach a larger group of people who are working with the Web App Builder.
SébastienMartin
You're right, thanks
StanMcShinsky
Martin Mimeault
You just need to add the
to the main config.json file in the root of the application.
        "version": "1.1",
        "index": 4,
        "name": "Legend",
        "label": "Legend",
        "openAtStart": true
-Stan
RobertScheitlin__GISP
Stan,
   Unfortunately that does not work for panel widgets as Martin is looking for.
JohnVarghese
Robert,
Is there a way to insert an image (jpg) in the legend area?
Thanks.
John
John,
  It would be possible using DOM manipulation. I.e. Using dojo query to find the legend Dom element and then insert a new img element into that Dom. I don't have a sample for this tough.
SébastienMartin
Thanks but as Robert says, it's not working as the widget is in the side pannel.
Must be somewhere in the javascript Panel.js or TabWidgetFrame.js but I can't figure it out...
DavidColey
MVP Frequent Contributor
Don't side panels have a toggle property?
StanMcShinsky
        "version": "1.1",
        "index": 2,
        "name": "Legend",
        "label": "Legend"
        "version": "1.1",
        "index": 2,
        "name": "Legend",
        "label": "Legend",
        this.createTabs();
-Stan
