Dynamic show the point in the map from web application
3052
03-16-2015 08:08 PM
kevintang
Dynamic show the point in the map from web application.
Yy web application will let the user input the x, y point. i would like to pass the x, y to arcgic server by published service.
what toolbox should i used  and how to do it.
Thanks.
OwenEarley
Do you want to just show the point on the map or pass it to ArcGIS Server to create a new feature using REST or a geoprocessing service?
To add a point to the map using the JavaScript API you can use the GraphicsLayer.
