Question about creating custom in-panel widget.
6265
7
03-16-2015 12:35 PM
SophieYe
Hi All,
I started to play with WAB recently. I am following the steps from ESRI's website:
Create a custom in-panel widget—Web AppBuilder fo... . Now I can see the custom widget in the widget pool. But after I added the widget to my app and clicked on it to test, it poped up a message saying "Create Widget Error". When I tested it through http://[your host name:3344]/webapp/?config=sample-configs/config-demo.json, I got the same error. (I have downloaded the missing sample-configs folder from GeoNet.). Then I started the steps for creating a custom widget all over again and tested step by step. And it worked fine until Step 8 "Access a map". After I followed the instructions to access a map, I got the Create Widget Error message. I am wondering if anyone has some ideas about how to solve this problem.
Thank you very much!
RobertScheitlin__GISP
Sophie,
   Sure in the manifest.json make sure your properties look like this:
"properties": {
        "inPanel":true,
        "hasLocale": true,
        "hasStyle":true,
        "hasConfig":true,
        "hasUIFile":true,
        "hasSettingPage":false,
        "hasSettingUIFile":false,
        "hasSettingLocale":false,
        "hasSettingStyle":false,
        "IsController":false
SophieYe
Any ideas about this? Thanks!
Sophie,
   Open your browsers developer tools and see what the console says
SophieYe
Hi Robert,
Thanks for your reply. Here is the information from the console:
  • GET http://[machine name]/webappbuilder/apps/12/widgets/MyWidget/setting/Setting.js 404 (Not Found) init.js:41
  • Error: scriptError {src: "dojoLoader", info: Array[2], stack: (...), message: "scriptError"}   init.js:41
  • src: dojoLoader   init.js:41
  • info: ["/webappbuilder/apps/12/widgets/MyWidget/setting/Setting.js", Event]    init.js:42
  • Uncaught SyntaxError: Unexpected identifier                  Widget.js:20
  • create [widgets/MyWidget/Widget] error:TypeError: number is not a function      WidgetManager.js:97
  • TypeError: number is not a function {stack: (...), message: "number is not a function"}
    • message: "number is not a function"
    • stack: (...)
    • get stack: function () { [native code] }
    • set stack: function () { [native code] }
    • __proto__: Error
       "TypeError: number is not a function
Any ideas from here? Thanks a lot!
Sophie
Sophie,
"properties": {
        "inPanel":true,
        "hasLocale": true,
        "hasStyle":true,
        "hasConfig":true,
        "hasUIFile":true,
SophieYe
Hi Robert,
Thanks. Now the "cannot get setting file" error is gone. But I still get the following errors:
    • stack: (...)
    • __proto__: Error
Could you please help me with that? Thank you.
Sophie
TimWitt2
Sophie,
this error is usually caused by unbalanced ( { [ within your widget.js
Tim
SophieYe
Hi Robert and Tim,
Thank you both so much for helping me solve this problem. After I balanced all "(, [, {", I still got the error. But it worked fine after I restarted the Web AppBuilder.
Thank you very much. I really appreciated your help.
Sophie
