Making points of data.
4492
03-15-2015 01:56 AM
SimonPeterzinek
I tried to install my own layer for Capercaillie in Slovenia region unit Kočevje, but it does not show up. I think that this is becouse of  a different use of the coordinate system.
NahedTaha_Hassan_Zeini
I think so.
XanderBakker
Esri Esteemed Contributor
In order to receive an helpful answer you may want to add some additional information to your thread. For instance you thread is missing tags to draw the attention of relevant member at GeoNet (Tagging Content ).
You place the thread in the 3D Mapping group. Is your data 3D? If not you may want to consider moving the thread to Managing Data space. (seeMoving Content​ ).
Please mention what application of the ArcGIS platform you are using and the coordinate system (spatial reference) and type of input layer.
SimonPeterzinek
I think I found the solutin, I just have to try it. Thanks for now. if it does not work I try my luck on on mamaginig data.
