I am attempting to embed audio in a Map Tour caption following the instructions here:
Adding audio to your story map map tours | ArcGIS Blog
It appears to work fine when I cut-and-paste the code block from the example into one of my map's captions. The audio control appears, and I can play the horse sound just fine. I then save the changes.
When I go to re-open the map, however, all the html code has disappeared from the description. Other text I had in the caption remains, but the whole <audio> section is gone.
Is this a bug? Is there a different way to include an audio file with player in the caption for a Map Tour point?
Thanks!
-peter
